stream crossing
axil beaerings differential breather
18 replies to this topic
#11 DavidGraves
DavidGraves
  • 1,267 posts
Posted 17 April 2021 - 11:23 PM
On the bearing issue...I am sure you know the old adage about boat trailer bearings....if they are highway speeds hot and you back into lovely cool lake water the moisture is "sucked" in by the temperature difference as the hub grease suddenly contracts and water is brought in through the seal.
I try to keep my hubs out of being submerged but then I have never be a "wheeler".
Sometimes you just gotta do what you gotta do......but only sometimes.
#12 ramblinChet
ramblinChet
  • Gone Traveling
  • 486 posts
  • LocationYorktown, Virginia
Posted 22 April 2021 - 05:25 AM
When I lived in Florida we spent much time driving my Jeep through 2-3' of water, sometimes for hundreds of yards. It is a good idea to extend the breather tubes for your axles, transmission and transfer case up high. You can also remove the fill plugs for your differentials and transfer case and if a frothy milky fluid comes pouring out you know you have water contamination.
For my RAM I will be ordering the ARB kit below. The manifold will accept four tubes although the kit only comes with two. Extra tubes and fittings are available for purchase.
Adventure vehicle: 2021 AEV Prospector & FWC Grandby Trail reports: Texas Hill Country, East Texas 450 Loop, Georgia Traverse, Allegheny Discovery Route, Laurel Highlands 200, Cross Pennsylvania Adventure Trail, Trans New Jersey Trail, Georgia Adventure Trail, Panhandle Adventure Trail, Cheeseburger Loop, Organs Loop, Sedona Backcountry Trail, Bloody Basin Trail, Crown King Road, Senator Highway, Big Bend Adventure Trail, Big Bend Ranch 150, El Camino del Diablo, Mojave Road, Joshua Tree Adventure Route, Anza-Borrego Discovery Trail, Kofa Pioneer Trail, Sonoran Desert Traverse, Five Tribes Overland Trail.
#13 buckland
buckland
  • 3,079 posts
  • LocationNew England
Posted 22 April 2021 - 10:41 AM
Thanks for both  of the above suggestions. I have wondered about what method would make sense and perhaps go with a pre-masde tube breather. The hot bearings is an issue that probably can only be solved by waiting for them to cool off before diving in.
Again thanks for the tips.
Lordwoodcraft  instagram        Rob
The only people who ever get anyplace interesting are the people who get lost.
Henry David Thoreau
"Work to achieve not to acquire"
#14 XJINTX
XJINTX
  • 552 posts
  • LocationEddy, TX
Posted 22 April 2021 - 11:50 AM
Here's a tame version.... of suddenly seeing a logging truck coming (btw one should have the latest version of CB ...the new type $$$ that the drivers use... one is expected to announce where you are)
https://youtu.be/HWP6za61yXE
What exactly are you referring to with the "New" CB? I was up in Northwoods last year and REALLY want to go back. I have and had CB but never heard any trucks... maybe that's why?
#15 buckland
buckland
  • 3,079 posts
Posted 22 April 2021 - 01:12 PM
They are called Micromobile  as well as GMRS    https://midlandusa.c...lo-micromobile/
The North Maine Woods is unique ... a privately owned area of a State that at one point was nearly 1/2 the land area. Now it is down to 25% or so. Development is always circling like carrion seekers... along the borders. Lake front is the thing.... A few conservationists, like the owner of Burt's Bee products have tried to out bid these developers and buy large swaths that become available. Trying to keep it wild and not filled with McMansions. Win some and lose some. As it has gotten more discovered... well you know the story.
Know these rules      https://www.northmai...mation.htmlhard copy mat
Also ... offline maps essential (best we have found is Maps.me)
Never go in without a hardcopy map Delorme is the best Maine Atlas. Log roads come and go yearly.
Be sure to have a way to get yourself out of a pickle.... there is no road rescue service.
Bring extra fuel. Log roads look like 30 miles on a map might be 60 miles due to many things.... like having to backtrack.
As to be expected the southern boundary  (the Golden Road area)  is highly used.
Don't forget Mt Katadin     https://baxterstatepark.org
They have very strict rules there too (no dogs... not even keep in camper)
I have been roaming around up there since 1975 and feel lucky that I had the chance.
Edited by buckland, 22 April 2021 - 01:13 PM.
Henry David Thoreau
#16 Dirt Rider
Dirt Rider
  • 162 posts
Posted 22 April 2021 - 02:22 PM
even with good venting, water seems to find a way in. Best bet is to drain and refile after deep water crossing when done with the trip.
#17 craig333
craig333
    Riley's Human
  • 8,022 posts
  • LocationSacramento
Posted 22 April 2021 - 04:39 PM
Are truckers going to GMRS there?
#18 buckland
buckland
  • 3,079 posts
Posted 22 April 2021 - 06:37 PM
Last time through the gate I was asked if I had one. Terrain there would suggest it is all that would work..... cell ... there is none.
Henry David Thoreau
#19 ntsqd
ntsqd
    Custom User Title
  • 2,881 posts
  • LocationNorth So.CA
Posted 23 April 2021 - 02:06 PM
Merely moving the vent up may not always be enough. Think about how long that new vent hose is compared to it's ID. Even in a fluid as viscous as air that long, small hose will be a flow restriction . I think if deep water crossings are a regular feature of your driving that the vent hose size should be increased to as large as is practical.
I don't know if the newer trans' are the same or not, but how Toyota vents their 80's era manual trans doesn't lend it self to easily extending the vent. Some domestics are no better, others have something similar to the part below.
Some Toyota vent fittings have a check valve in them. Debatable whether or not this is a good thing.
I recently stumbled onto this fitting for extended breather/vent hoses: https://www.amazon.c...t/dp/B06XHBY38X
Edited by ntsqd, 23 April 2021 - 02:08 PM.
Thom
Where does that road go?
