A couple hours ago I hooked the batteries to my Noco genius 7500 which will slowly bring my batteries up to full. Based on your suggestion I looked at the Lion Energy FAQ and saw,
Victron inverters charger and charge controllers should be set to 13.9 volts for a 12 volt inverter and 27.8 for 24 volt inverters."
Based on the above Im guessing I should change the charge voltage from 13.2 to 13.9? Or should I go higher?
steve
Well, personally, I'd go with what your manufacturer suggests. If they say 13.9 then try it. BB suggests ~14.2 based on a 14.4 absorption. You'll know in a day when the solar charges it up.
