+1 on the lousy bluetooth range with the DCDC. The other Victron units work from 50' away, the DCDC won't even reach the cab of the truck.
Victron Orion DC-DC Charger Question
#31
Posted 06 December 2021 - 07:48 PM
#32
Posted 06 December 2021 - 11:19 PM
+1 same here... I have to hold the phone and put it into the back seat (3 ft from the unit) to get a a link
#33
Posted 30 January 2022 - 03:14 PM
I know it's likely a silly question but what happens if my solar is on the input side of the Orion DC-DC charger so that it would also keep my truck battery topped off? One problem I see is the MPPT would be set to either AGM profile or Lithium. Ron
Edited by nikonron, 30 January 2022 - 03:24 PM.
#34
Posted 31 January 2022 - 12:03 AM
Are you suggesting that the raw output of the solar panels go to your truck batteries? Not good.
If you are suggesting feeding the output of the MPPT into the DCDC and from there into the truck batteries, the MPPT would be awfully confused, not knowing what to make of the input side of the DCDC.
I battery switch or switch and relay to flip inputs would be better. I tried creating a really complex system last winter and gave up. I think a simple battery switch in parallel with the DCDC would enable you to bypass the DCDC when desired. The downside of that is a simple switch (vs including an ACR/Isolator) would mean it either system could drain the other.
If you still have an isolator, you could wire the bypass to include the isolator, essentially going back to how your system worked before the DCDC was installed.
#35
Posted 31 January 2022 - 12:15 AM
I am basically always on the line of confused and understanding… so great to read these threads picking up bits that build the bigger picture
Thanks Vic
#36
Posted 31 January 2022 - 03:01 AM
I suppose the Victron is way too smart, I'll just wire it up as per Victron specs.
Edited by nikonron, 31 January 2022 - 08:21 AM.
#37
Posted 31 January 2022 - 08:19 AM
What's going to happen if I should connect a battery charger to the starter battery while the truck is sitting in my shop? Should I disconnect the Victron DC-DC charger via my resettable breaker?
#38
Posted 31 January 2022 - 05:57 PM
Jon R
2021 GMC 3500HD CC LB SRW Gas
#39
Posted 31 January 2022 - 07:21 PM
Well, if it doesn't hurt anything it'd be good to get the Lithium topped off too.
#40
Posted 31 January 2022 - 07:59 PM
Except if you are charging the truck during extended storage. Most battery companies recommend you store lithium batteries in a partially charged state. In that case you may want to disconnect the camper if you are charging the truck.
Jon R
