JUtah
Mar 12, 2022
2
Selling my 2016 Toyota Tacoma TRD Off-Road Manual 6 Speed with 2020 Four Wheel Camper Project M 5.5. Full description / pictures in the link below:
https://cars.ksl.com/listing/7749356#
Selling my 2016 Toyota Tacoma TRD Off-Road Manual 6 Speed with 2020 Four Wheel Camper Project M 5.5. Clean Title. Selling as a package, I currently don’t want to split them up. I am the original owner of the Four Wheel Camper, and second owner of the truck, purchased from the original selling dealership in 2019 after the original owner traded it back into Hometown Toyota Oregon for another newer tacoma. Selling because I just purchased a new full size truck, going to miss this one. All maintenance up to date, oil changes/tire rotation every 5k miles. Well cared for and ready for a new home. Includes full camper setup, External 10LB propane tank and furnace hookups, etc. modifications/build sheet listed below, lots of stuff probably not mentioned.
[SIZE=11pt]Truck:[/SIZE]
[SIZE=11pt]2016 Toyota Tacoma TRD Off-Road V6 Manual 6 Speed [/SIZE]
[SIZE=11pt]93,000 miles[/SIZE]
[SIZE=11pt]Red factory paint color. Great shape underneath. [/SIZE]
[SIZE=11pt]Avery Dennison Matte Gunmetal Metallic Vinyl Wrap installed by Vinyl Wurx in Woods cross, UT.[/SIZE]
[SIZE=11pt]Fully loaded, tech package, premium package, Sunroof etc. Highest level TRD off-road available that year.[/SIZE]
[SIZE=11pt]Carbon Ceramic window tint all around, 85% windshield and sunroof. [/SIZE]
[SIZE=11pt]Sound system: Full Triton Audio speakers and tweeters all around. Kicker amp Custom mounted behind rear seat with storage room. Custom built sub box / kicker subwoofer behind rear seat storage. Subwoofer control knob mounted by switch panel.[/SIZE]
[SIZE=11pt]Roadwire leather kit.[/SIZE]
[SIZE=11pt]TRD shift knob, stock shift knob included. [/SIZE]
[SIZE=11pt]Baja Designs Squadron Sport Fog lights yellow.[/SIZE]
[SIZE=11pt]Suspension: [/SIZE]
[SIZE=11pt]Bilstein 5100s front and rear.[/SIZE]
[SIZE=11pt]OME Springs in front set on lowest strut settings.[/SIZE]
[SIZE=11pt]OME Dakar +650lb leaf pack in rear.[/SIZE]
[SIZE=11pt]OME Carrier bearing drop kit.[/SIZE]
[SIZE=11pt]Swaybar relocation kit front.[/SIZE]
[SIZE=11pt]Artec industries front A-arm sliders.[/SIZE]
[SIZE=11pt]Wheelers U-bolt Flip Kit [/SIZE]
[SIZE=11pt]Front differential clamshell bushing installed by Agility Customs, fluid changed.[/SIZE]
[SIZE=11pt]Wheels & Tires:[/SIZE]
[SIZE=11pt]Method MR305 NV wheels 16 x 8 +0[/SIZE]
[SIZE=11pt]Falken Wildpeak AT3 10 Ply E rated.[/SIZE]
[SIZE=11pt]Camper:[/SIZE]
[SIZE=11pt]2020 Four Wheel Camper Project M 5.5[/SIZE]
[SIZE=11pt]Installed new at Equipt Outfitters in SLC spring 2020.[/SIZE]
[SIZE=11pt]Entire interior build could be stripped/removed in under an hr if not wanted. Lightweight aluminum/ABS build weighing sub-100lb.[/SIZE]
[SIZE=11pt]Roof Vent Fan - rain sensor, etc.[/SIZE]
[SIZE=11pt]Passenger window.[/SIZE]
[SIZE=11pt]Driver Window.[/SIZE]
[SIZE=11pt]Thermal Insulation Pack (great for summer and winter, camp in negative temps comfortably).[/SIZE]
[SIZE=11pt]Roof lights (dimmable).[/SIZE]
[SIZE=11pt]Carbon Monoxide alarm.[/SIZE]
[SIZE=11pt]Prewired for exterior rear lights.[/SIZE]
[SIZE=11pt]Prewired for Solar, solar setup.[/SIZE]
[SIZE=11pt]FWC OEM Mattress. [/SIZE]
[SIZE=11pt]Yakima roof tracks (roof racks not included, could be negotiated into price).[/SIZE]
[SIZE=11pt]Renogy 100W solar panel.[/SIZE]
[SIZE=11pt]‘[/SIZE]
[SIZE=11pt]Off Grid Engineering secondary battery tray with 124AH FLA house battery under hood.[/SIZE]
[SIZE=11pt]RedArc BCDC1225 DC - DC dual battery controller/Solar controller. Handles dispersion of all battery charging, charges camper battery from alternator and solar panel, giving priority to solar. Separates truck battery from camper battery so you wont drain the truck battery. I have yet to drain the camper battery below 85% charge running furnace, fan and lights all night.[/SIZE]
[SIZE=11pt]Victron Battery Monitor flush mounted in camper.[/SIZE]
[SIZE=11pt]USB / USB C Chargers in camper. Can be turned on/off. [/SIZE]
[SIZE=11pt]BlueSeas Fuse box in camper.[/SIZE]
[SIZE=11pt]Propex HS2000 furnace mounded in camper. Electronic thermostat mounted in sleeping area “upstairs”. Exhaust mounted through truck bed, exhausts in front of passenger rear wheel. Combustion intake piped inside of truck frame w/ P trap. Custom copper hardwiring for propane leading from furnace under truck bed to quick connect hidden inside Otterbox mounted under passenger rear bedside. Soft line is then run from Propane can mounted on exterior of camper through soft line to hardline. 30 second furnace set-up at camp. [/SIZE]
[SIZE=11pt]AT Overland 10lb propane tank mount.[/SIZE]
[SIZE=11pt]10lb propane tank included. [/SIZE]
[SIZE=11pt]Dual stage propane condenser included.[/SIZE]
[SIZE=11pt]Bedrug.[/SIZE]
[SIZE=11pt]Truck / camper is located in Salt Lake City, UT. Open to reasonable offers. Great truck and I am going to be sad to see it go. Call/Text with any questions. phone number - 8zero1 58zero 1764[/SIZE]
bump, price drop to $55k obo. Will sell truck alone for $39k obo
