Dave - I can't find the bottom drawer on their web site, but here are the big ones.
https://www.containe...uctId=10024854 They are both made by "like-it"
The bottom drawer is there to equal the height of the carpeted ledge. I went into the store with a tape measure and bought anything that looked like it would fit, took it out to the camper in parking lot and tried it out.
I found the aluminum frame by removing some screws holding the thin veneer that covers the inside of the camper. I was only able to peal it back at the top and peer into it from the top with a flashlight and a measuring tape and then make marks on the veneer with a pencil. To mount the drawers I had to: cut a little off the side curtain track, move the fire extinguisher (see photo for new location), and move the storage rack forward (two of the three were less than a 1/2 inch wrong).
I put one sheet metal screw into the wall in the back of each drawer and one screw into the side. On the side I used the screws that hold the back window in. All screws had fender washers on them. The top drawer is above the window so I put a piece of wood in between the back wall and the drawer (the thickness equaled the window standoff from the back wall) and then screwed through the wood into the back wall.
Edited by Flyfisher, 11 August 2022 - 12:12 AM.
