Blue Sea automatic charging relay- why is it on all the time?
12 replies to this topic
#11 steve whiteside
steve whiteside
  • 183 posts
  • LocationSan Diego CA
Posted 30 October 2022 - 09:08 PM
The ML-7622 ACR has a lockout. When mixing Li and Lead acid, the higher resting voltage of the lithium battery will keep the ACR connected and drain the camper battery until the voltage drops enough.
not good if you want to keep your camper batteries at max charge, great if you want to trickle charge your truck batteries.
Well said!  thanks, I guess when my camper is in the stored position I could always pull that fuse.  Ot put in another 12 v switch.
Steve
2012 F350 4x4
2020 Grandby
#12 pvstoy
pvstoy
  • 2,772 posts
  • LocationCarson City, NV
Posted 31 October 2022 - 12:30 AM
I have the 7622 with the manual 3 position rocker switch. Works well for our setup. It is in the off position all of the time since we have lots of solar. Parked in the shop I can plug in the camper charger and switch the rocker to lock both banks together and charge also the truck battery. All batteries are AGM.
I have the option while camping IF solar is not keeping up to use the alternator to help bring up the camper batteries. Good for jump starting if truck battery is dead.
If I had lithium in the camper I would remove it and install DC to DC charger with a rocker switch to work the same way.
Now I can see if I wanted to use the 7622 until time would alow to install a DC to DC unit here is a thought.
Get the three way rocker switch. Install it in a convenient place in the cab. While driving have the system in auto. When turning off the engine switch the rocker to turn off position so that the two banks of batteries don't see each other.
Years ago rando posted how to use the units ground wire as a switch.
But I would just get the DC to DC charger installed and move forward with one less thing to fiddle with. Cheers...
Edited by pvstoy, 31 October 2022 - 12:34 AM.
  • 1
Patrick
2015 FWC Hawk Flatbed
#13 Jon R
Jon R
  • 933 posts
  • LocationWashington State
Posted 31 October 2022 - 05:42 PM
If you use a Victron Orion you don’t have to install a switch because it has a software switch allowing the charger to be disabled from the Victron Connect app on your phone. I use that software switch for all normal seasonal switching, but I pull the SB50 connector to the truck if I’m doing electrical work.
Jon R
2021 GMC 3500HD CC LB SRW Gas
