Renogy Controller & Battery Install
15 replies to this topic
#11 Defulmmt
Defulmmt
  • 33 posts
  • LocationMontana
Posted 17 August 2023 - 09:50 PM
Heh Ski3pin,
I wanted to follow up on your experience with the Renogy controller. Are you satisfied with the performance and system design after several months of use?  You mentioned in your review that you didn’t note much heat emission from the controller.  What is the heat level when the unit is charging via the alternator?  I’m planning an electrical system upgrade on my Panther and researched products from Renogy, Victron and Redarc.  The Renogy appears to have a cost and simplicity advantage.
The Panther came with a Renogy solar controller, 160 watt solar panel and a 79 hour AGM battery.  I added a Renogy bluetooth connection to the controller and a battery SOC monitor.  I plan to upgrade to a dcdc charger and 100 amp hour Battleborn.  I am inclined to just make this an all Renogy system but, then again, buy the best tool first and only cry once.
Any feedback on the Renogy system will be appreciated.
 I think the WTW forums are great, in more ways than one.  Thanks to all who make this such a useful resource.
2021 ATC Panther
2019 F250 Superduty
#12 rubberlegs
rubberlegs
    curmudgeon
  • 564 posts
  • LocationEverett, WA
Posted 18 August 2023 - 05:17 AM
I had several nice chats with Mr. Ski3pin and also got the Renogy he used, but decided on the 30A unit. I figured it would get less hot, because the box and heat fins are the same as the 50A version as far as I can tell. The only convenient place to mount it was in the battery compartment on our side dinette camper. So I mounted it right over the two vent holes. I was pretty concerned about overheating inside the battery compartment. Lithium batteries don't need venting, so using the holes for cooling seemed reasonable.
Other reasons for the 30A dual-charge controller besides less heat: less stress on the alternator, charges the battery slower so maybe less stress on it (we generally drive for at least 30 minutes), possibly could have used 8 gauge wire instead of 6, but we did use 6 from truck battery to camper battery, and there's another reason but can't remember right now! It didn't cost much less than the 50A version though. That was disappointing.
Frankly, the heat hasn't been much of an issue so far (6 months usage) because our power needs are pretty low. Just a fridge, charging gadgets, lights, and sometimes the heat and fan. Our SOK 100 AH lithium battery only drains 20% per day, maybe 25% on super warm days. Solar will keep it a lot higher than that, usually 10% overnight. Most of the time our battery stays above 80% SOC. I unplug the camper, awkwardly, through a turnbuckle door on the last day or two of a trip to discharge it below 100%.
It seems like we either move every day a little bit, enough to charge it, or solar keeps it charged. The way our truck is wired we don't really get 30A, more like 25A, and it never seems to get very hot. So it charges up in about 45 minutes or less when driving.
When using our 100W flex solar panel on the ground it's only charging at around 5 amps, which doesn't heat up the charge controller. It easily keeps up a full charge if we get reasonable sun. Honestly I feel like I only use solar to save gas, which I figure is about 0.15 gallons for a charge from 0%-100%. But we've never stayed more than 3 nights without driving somewhere. The Renogy charger will produce some charge amperage even in cloudy weather, especially if we add our other 90W suitcase panel.
Basically I'm very satisfied with the Renogy dual controller and the SOK lithium battery. I'm sure the other name-brand battery manufacturers are good also. (Except our older SOK battery Bluetooth doesn't report state-of-charge correctly, so I got a cheap non-Bluetooth SOC monitor.)
Yes, this forum is fantastic for many reasons! I'm curious how Mr. Ski3pin will reply to this, as he has much more experience.
Tacoma/Fleet 2018.
#13 TacomaAustin
TacomaAustin
  • 171 posts
  • LocationAustin, Texas
Posted 18 August 2023 - 03:39 PM
(Aside from its $200 price when marked down), just like Rubber legs stated, the main reason I went with the smaller charge controller was to minimize the strain on my 18 year old, 130 amp alternator in the Texas heat.  The 30 amp Renogy dual input charge controller has been in continuous use for only 1 year.  I used #6 gauge wire on the run from the charger and camper to the truck battery.
I had been using an older CTEK unit and an AGM battery for about seven year.  Unfortunately,  the CTEK did not offer the correct charging profile for my LiFePO4 upgrade.
Quirks:   I have a 175 watt panel on the camper's roof - which is connected to this charge controller.  So, when I'm driving during daylight hours,  the maximum number of amps that it will draw from the alternator is about 15 A.   The charge controller prioritizes solar.
So far so good, fingers crossed.   My main worry is the Renogy DC-DC with MPPT charge controllers have some terrible reviews on Amazon.
Andrew in Austin, TX
#14 rubberlegs
rubberlegs
    curmudgeon
  • 564 posts
Posted 19 August 2023 - 02:40 PM
That’s a good point. If you have solar on the roof, the alternator side will only draw half amps on that particular Rengy charger. So that’s a way to mitigate heat. we don’t have roof solar, so ive seen 25-30 amps.
Edited by rubberlegs, 19 August 2023 - 02:42 PM.
Tacoma/Fleet 2018.
#15 ski3pin
ski3pin
    Belay On
  • Site Team
  • 15,346 posts
  • LocationSierra Nevada Range
Posted 28 August 2023 - 03:38 PM
Heh Ski3pin,
Julie and I just returned from an extended adventure. The Renogy system works well, well enough that I hardly think about it. Just the way I want it. Three times we parked in mostly shade for three to four days. The lowest the 100amp hour battery got to was 75% SOC. Our power needs are small - part of the system planning. Our chest style 51 L truckfridge is the main consumer of power in the summer. I have noticed no issues with heat during charging from the alternator - max of 25 amps since we have solar. Of course I'm driving at the time and am not inside the camper with my hand of the unit. But, I've not felt or seen any heat issue.
It keeps working and I don't have to think about it. Julie has the DC Home app on her phone and she gets curious about it and checks the app during trips, such as SOC in the morning and how much recovery during the day parked mostly in the shade. "Little Miss Technology," who would have thought?
  • 1
#16 Defulmmt
Defulmmt
  • 33 posts
  • LocationMontana
Posted 06 September 2023 - 11:08 PM
Thanks all for the feedback.  The amp limit when the controller is coupled to solar led me to order the 50 amp version.  I also ordered Blue Sea 80 amp breakers and 6awg cable.
 I really enjoy the dc tutorial I learn on this forum.  It’s got me thinking about building a 5kw backup system for the house.
  • 1
2021 ATC Panther
2019 F250 Superduty
