New Hawk Quirks
#1
Posted 04 September 2023 - 08:30 PM
Second one, and perhaps more alarming, is these two bubbles under the bed. It seems the adhesive is coming undone.
I plan on following up on both of these but figured I’d see what people here think as well.
#3
Posted 04 September 2023 - 08:42 PM
FWC Slide-in Grandby and OEV Aluma Tray on a Ford F350 Supercab with the 6.2L Gas Engine.
IG: heinphoto
#4
Posted 05 September 2023 - 04:51 PM
I'm not sure what you mean about the lock problem, but that bubbling is definitely a warranty issue and most likely the lock as well. Reach out to your dealer. Bummer about the inconvenience this will cause.
Dean and Mary
2015 RAM 2500 Cummins with 2015 Four Wheel Campers Hawk flatbed
VeryActiveLife on Facebook, instagram & YouTube
#5
Posted 05 September 2023 - 07:19 PM
Definitely contact Stan at FWC .The issues aren't normal ,it's a brand new camper?
#6
Posted 05 September 2023 - 08:12 PM
#7
Posted 05 September 2023 - 08:22 PM
I bought a Hawk in 2021. I was amazed at the lack of quality control.
Edited by Ouroboros, 05 September 2023 - 08:24 PM.
#8
Posted 05 September 2023 - 10:21 PM
Brand new camper. Just left a message with their service department. Issue is the dealers are far from me and hunting season is right around the corner which I got specifically for.
Welcome to the cult.
They should take care of it.I would think that once you start the warranty issue the clock stops ticking,you would think.
Good luck.Stay on top and don't let them not take care of your problems.
#9
Posted 05 September 2023 - 10:47 PM
#10
Posted 05 September 2023 - 10:52 PM
In the meantime I got the ok to do a short term fix to keep using it. I’m thinking I will make a small pin hole and put a flat piece of wood under it for a day or two and see if it will adhere again, at least temporarily, to keep it from getting worse. Now I ask the hive mind, is it worth trying to inject some kind of adhesive? Honestly if it was a permanent fix I’d be fine with it if it means not sending my camper all the way back to the west coast from the NE.
