I would really love it if the water tank in our 2017 Fleet could take care of all our water storage needs, but the system imparts such a strong taste of plastic to stored water that it's difficult to drink. For now, our only solution is to use the Fleet's water system for dishes and bathing, while also lugging around containers of water for consumption. The water I'm putting into the tank is coming from our municipal supply, going through a drinking-safe hose and an RV filter before it goes into the tank. It's fine before it goes in, so it's definitely the system imparting the plastic taste.
Has anyone here figured out a way to improve the camper's water system in this regard? A major mod would be replacing whatever parts are causing the problem, like maybe a storage tank made out of a different type of plastic. Filtering the water coming out of the system might be easier. An in-line filter would be great if the pump can handle the flow resistance that would impose. Otherwise, maybe filtering water after it comes out of the tap, though that would add stuff to haul around and time to use. Ideas?
