How Many Lifted Trucks Here?
#11
Posted 16 November 2009 - 04:24 AM
#12
Posted 16 November 2009 - 04:23 PM
The higher you go the wider you need to offset the foot print because you just raised your center of gravity. That is just for the truck alone. Now add a FWC and the center of gravity changes. Thought the FWC is great and can go anywhere, why create a hazard of rolling over while on trail.
Raising does help departure and approach angles but you can add bumpers and skid your way.
Tires, yes get wider as you go with a taller lift. The talk about gaining a lot of differential clearance by increasing diameter is true to a point. The tire is squatting on the bottom side and then you take air out for traction and performance on the trail. If you really want the max diff clearance you need to go big diameter. There are rock skids available or have custom made for protection.
Your driving style and experience off road is the most important factor and knowing the limitations of you and your truck. Make it right and make it safe for all
Patrick
2015 FWC Hawk Flatbed
#13
Posted 16 November 2009 - 04:26 PM
Patrick
#14
Posted 16 November 2009 - 04:38 PM
I've ran rigs with 8" lifts and such in the past and that combined with youthful vigor usually means you're going to be wrenching a fair amount, haha. Since now you are stressing out stock components (like joints, etc.) and getting into stickier situations and such.
#15
Posted 17 November 2009 - 05:04 PM
No lift on this rig, I don't need it at this point. Down the road if I start hitting terrain requiring it I'll ponder my options and truck selection more.
Edited by 85K54WC, 17 November 2009 - 05:06 PM.
#16
Posted 17 November 2009 - 05:57 PM
JayAronowSales.com
(520)579-9610
jayaronow@gmail.com
#17
Posted 18 November 2009 - 02:08 PM
