electrical (charging and fridge)
plan to rewire the 12v to the fridge and bypass the original fuse, probably pick up an inline fuse, any thoughts on sizing the fuse? i'd also like a manual switch to ensure the fridge does not deplete the battery
Check with the maker of your fridge, or somebody here for the amps of your 12v heating element. Then use an inline fuse with more amps than the element. Most elements seem to be 7-15 amps range so you could ballpark the fuse at 20amps if you are only going to run the fridge on that line.
How do you switch between 12v, 120v and propane now?
Stew
