Furnace Problem
#21
Posted 25 May 2010 - 10:08 PM
2003 Ford Ranger FX4 Level II 2013 ATC Bobcat SE "And in the end, it's not the years in your life that count. It's the life in your years."- Abraham Lincoln http://ski3pin.blogspot.com/
#22
Posted 25 May 2010 - 10:11 PM
#23
Posted 25 May 2010 - 10:15 PM
Hope this info will help someone.
#24
Posted 25 May 2010 - 11:11 PM
#25
Posted 01 October 2013 - 03:03 AM
I reference this thread to install a new fan motor in my Hydroflame 8516 today. made the job much easier! Great information here!
Thank you ski3pin!
CWD
#26
Posted 01 October 2013 - 06:11 PM
I pulled the furnace out today to get a look at it. Door came off the outside, inside vents and cabinet around it on the inside off, check for extra screws holding it in place (found one inside), removed the small heat vent duct, removed the exhaust port to easily get at the propane supply connection, pulled it out the outside access and clipped the four wires at the old connectors.
I would add that it isn't necessary to clip/cut the 4 wires. Slide the unit out far enough to access the connector and pinch the tabs to release it from the metal frame and pull the wires out the hole in the top.
CWD
#27
Posted 22 February 2015 - 10:01 PM
Nice job on that motor Ski. Thanks for the pics. If I ever need to fix one I will know what to do!
2018 Ford F-250. Customized Bundutec Sable
