What brand awning for eagle?
#11
Posted 24 June 2010 - 07:24 AM
I considered doing this and looked at the roof. Probably not strong enough. Over the door, on the main camper wall there is just not enough room.
If you have the jack points, you could fabricate a way to essentially mount the shady boy slightly away from the rear wall, above the door, but next to the pop-up roof so that you could deploy it here and still raise the roof. I have thought of doing this. But, would rather have the convenience of the carefree truckin' awn back there instead. If I can find a used or ebay unit for cheap, may try to construct one here. But, that is another topic and issue.
Good luck.
dave
#12
Posted 24 June 2010 - 11:28 PM
Thanks. Anyone know of an awning that can be mounted over the back? I'm not going to build one as others have.Shady boy cannot be mounted over the rear door. Probably could do it with some mods, but needs some nice strong attachment points.
Good luck.
dave
Now, just roaming around in a stock Land Cruiser (not stock for long though... bawahahha [evil laugh])
#13
Posted 20 November 2011 - 03:07 AM
This link shows a Shady Boy attached over the rear door of an Eagle. Two two inch long pieces of 1 inch aluminum square stock make perfect spacers to allow the clearance needed to mount the Shady Boy. I staggered the awning so it has more coverage on the rear left side where we set up the bbq on a collapsible table using the second propane tank. I drove out to White Rock B.C. to the supplier to see if I could make the awning work, he suggested the spacers which worked perfectly. I bought a couple of stainless bolts (the supplier told me the size to get) and used washers and cap nuts on the inside.
https://www.wanderthewest.com/forum/index.php?app=gallery&module=images§ion=viewimage&img=9161
#14
Posted 21 November 2011 - 07:43 PM
http://www.sleeoffro..._rhino_main.htm
#15
Posted 26 December 2015 - 05:29 PM
I realize this is a very old thread, but, just purchased a new to me 05' Eagle. It has a 8' Fiamma passenger side awning, very nice feature. I would like to make it nice again, decals , remove rust from camper jack mounts etc... any way, I watched a youtube video on the "new" rear awning option available on the new FWC line up. Well..., I live in colorado and will not drive to Calif. to have the "new" awning installed, so , Those of you that have the smaller version of pop up's what do you [storage space is a premium ] do for a rear awning?
Thank you,
Don
Edited by Mickey Bitsko, 26 December 2015 - 05:31 PM.
#16
Posted 27 December 2015 - 02:59 PM
I have the FWC rear awning on my 2014 Eagle and like it. You might see if FWC will sell the track that goes above the rear door; if so you could install it yourself.
#17
Posted 27 December 2015 - 03:20 PM
Pretty sure the track is installed on all the campers now. You can purchase the sail track on line, just do a search for it. Ron
