Kitchen Organizer
#11
Posted 30 January 2011 - 08:35 PM
This is two Camco Pop-a-Towel racks with some webbing, a couple of Fastex buckles and a few pop rivits. Real simple. The Fastex buckles were used so the bottom portion of the towel rack can be quickly disconnected if you only want to run one roll of towels. They also allow the bottom towel rack to be infinitely adjustable for height.
When lowering the roof I just slide the towel racks out of the sliders and leave the webbing attached to the camper.
2010 Ford F250 4X4; 6.4 Powerstroke Diesel; Warn 16.5 winch; Airlift Springs; Transfer Flow 47 gal. fuel tank, BDS 4" lift kit, BDS dual steering stabilizer with upgraded Fox 2.0 shocks, Toyo 35X12.50X18 Open Country M/T tires, Pro Comp wheels; 2008 FWC Hawk Camper; 2000 Toyota Tundra.
#12
Posted 30 January 2011 - 08:48 PM
Very nice arrangement .What do you do with all the kitchen mods when you use the bed?Do you have the extenda cab?
Thanks for the pics
Frank,
Here's are a couple of pics with the slider all the way out. It only impacts the kitchen organizer slightly. Nothing to worry about.
#13
Posted 30 January 2011 - 08:56 PM
This strainer is great. It fits right in the sink when not needed. You can also store some small items inside as the bottom snaps on the top as a lid when storing.
#14
Posted 30 January 2011 - 08:59 PM
#15
Posted 30 January 2011 - 09:00 PM
Wow, color matched and double paper towels!!! Must be related to Martha Stewart
I met her in prison.
#16
Posted 30 January 2011 - 10:38 PM
Camco makes some nice camper stuff. I have a few things for the upcoming camper from them.
www.KuenzliPhotography.com
2012 Four Wheel Camper - The FWC Build
"If life was fair, Utah would be closer to home" DD
#17
Posted 31 January 2011 - 07:15 AM
That said, for the towel racks, I have just gone to using some rope.....string it through the roll of towels and stick it up. Easy to take outside, easy to leave in the camper and I can hang it from anywhere. Moving it for sleep is easy as well.
Keep up the good work.
Dave in Seattle
#18
Posted 31 January 2011 - 10:13 PM
Frank,
Thanks for the pictures looks great. As small as our campers are things can be adapted to fit needs.I have a ATC bobcat so my bed is 48"x62" enough sleeping room so I don't need the extra pull out so the extra cushions stay home.
#19
Posted 31 January 2011 - 10:21 PM
I have the extended bed too....even with my girlfriend along, I haven't needed to pull out the bed either...so I leave the extra cushions at home.
#20
Posted 03 November 2013 - 07:23 PM
I finally got around to making a kitchen organizer for my Hawk. I wanted one that would fold down with the top so I wouldn't have to mess with it when putting the top down. I also wanted it to fully utilize the velcro strips located on top and bottom of the soft sides (ie. no holes drilled into the camper).
Here's some pic's of the results. The third picture is of the organizer folded in the top-down position. The paper towel holder does have to be taken down....but it just slides out of a dovetail (very quick).
where did u find a hanging bag like that. i need for my grandy as well as my locker at work
