Will it not be in an area you can reach with an extension cord?
If you can just plug it in for a day once a month and you'll keep the batteries topped up fine (assuming you don't have any little power draws going on, I don't in mine).
Another trick if not using a good float charger is hook the charger to your auto garage door circuit so when ever the garage door opens or closes you get a few minutes of charging.
