Fridge Fan Exhaust
#11
Posted 15 August 2011 - 06:58 AM
It is a pain to have to remember to turn it down at night or everything freezes.
2010 Ford F250 4X4; 6.4 Powerstroke Diesel; Warn 16.5 winch; Airlift Springs; Transfer Flow 47 gal. fuel tank, BDS 4" lift kit, BDS dual steering stabilizer with upgraded Fox 2.0 shocks, Toyo 35X12.50X18 Open Country M/T tires, Pro Comp wheels; 2008 FWC Hawk Camper; 2000 Toyota Tundra.
#12
Posted 15 August 2011 - 06:03 PM
How about some pics!
Thanks~
DR
#14
Posted 16 August 2011 - 02:00 AM
#15
Posted 16 August 2011 - 11:26 PM
Yesterday I set the fridge to Med on the lpg setting and the fridge was about 48 degrees. The outside temp was about 86 degrees. Usually with the gas on high it would cool to about 50 degrees.
Today it is 90 degrees. The lpg setting is on high. The fridge has been in the sun all day. The temp inside the fridge is 40 degrees.
I may add another exhaust fan but I think I have resolved the main issue.
Roger
#16
Posted 17 August 2011 - 03:35 AM
FYI - I got this fan: http://www.amazon.co...3NC15J8KN28N1ED
It has two thermal switches (one attaches to the reefer coils) to turn on/off at a preset temp. The other one monitors ambient temp.
The ambient temp and the coil temp must be >80 to turn the fan on. Otherwise it not cool properly. After all it is a "still".
Seems to be a well thought idea.
Edited by Desert Rancher, 19 August 2011 - 04:35 PM.
#17
Posted 19 August 2011 - 05:20 AM
I rolled up some reflectex and zip tied it in a roll to create dead are space in my unit. I had about 1 inch on the (facing the fridge from the outside) right and about 2 inches on the left. I didn't even bother with the top as it was less then a half inch. The two fans and the exhaust stack helped the most.
Thanks Rodger, that's sufficient to get the general idea. I was thinking about using the reflectex insulation on the sides and top, since there is very little room.
#18
Posted 20 August 2011 - 06:18 AM
DR,
Where did you install the second fan and is it the same as the one discribed in your 1st post?
Thanks,
CWD
#19
Posted 20 August 2011 - 04:42 PM
Thanks,
CWD
I installed a 120 MM case fan as the secondary. I think it was $7 at Fry's electronics, a way better deal than Radio Shack.
Specs
.33 AMp
57 CFM
140 Grams
You can see part of my Aluminum baffle in the "fridge bottom" pic. I installed the bigger fan on other side of the vent, again blowing out. I think I spent about $45 total on this project and I still have 8 feet of sheet aluminum left over, it was the most expensive item.
#20
Posted 21 August 2011 - 05:15 AM
Thanks,
CWD
