Both good ideas! Thanx Stan. Do you have those legs??
My biggest beef with my FWC...
Started by
Tomas Tierra
, Aug 08 2007 05:24 AM
25 replies to this topic
#21
Posted 10 August 2007 - 05:05 AM
#22
Posted 10 August 2007 - 06:06 AM
Thanks Stan, Ben, Jim and everyone for the suggestions for me.
I'll pull the front off to check the lines first. Then I guess I just need to give it a shot filling it up and have plenty of towels and buckets nearby. Good tip on flushing with some disinfectant.
- K.C.
- K.C.
#23
Posted 10 August 2007 - 04:17 PM
Hello Thomas Tierra
you wrote: << Do you have those legs?? >>
Yes, I think we have a box of them out in the shop we use for repairs on older campers.
Just call Chicali in our service dept. if you would like to order one.
CHICALI 800-242-1442
Yes, having a 3rd leg would help some too.
Yes & No for the "L" shaped couch. My older Grandby had the "L" shaped couch, but the portion of the couch that folded out was not part of that "L".
You should be fine with the long, straight couch once you beef it up.
Another idea to consider ...
I have seen a few people go the the local hardware store and purchase some pipe, screw in pipe base, and small rubber cap for the end of the pipe leg.
They will screw / mount the pipe base to the botom of the couch.
Then when they are ready to set the couch/bed up, they just screw in the 2 pipe legs. It is crude, looks kinds goofy, but seems to work well and is very solid !
I tried to find some pics of this set up, but none to be found ?
Hope all this helps
Hope all this helps
Woodland, CA 95776
www.fourwh.com --- e-mail = stan@fourwh.com
#24
Posted 10 August 2007 - 04:41 PM
I am working on a re-design of the couch||bed for my recently acquired 2001 Hawk; we (and the previous owner) have had similar problems with the legs, plus I want to slightly reposition the thing to add more clearance beneath when in couch position and more walking room when in bed position.
I'm right now in the AutoCAD stage. When the design got to the building stage I was going to take pictures and then report the results in the appropriate forum.
Look for a report within a month or so...
#25
Posted 10 August 2007 - 06:27 PM
I checked the hose last night and it is as high within the space as it can be. Looks like the method will be to top the tank and then drain off about a gallon.
DLN
Ex- 2006 Eagle - 2002 Tacoma TRD - Ride Rite Air Bags
Current - 2004 17' Casita SD
#26
Posted 11 August 2007 - 04:47 AM
When you top off the tank, you should really only have to drain off about a quart of water at the most. When it squirts water out at you when you are filling it, the fill hose and vent hose are full of water and that is what leaks out as you start driving.
If you drain just enough to clear those hoses, you should be fine.
