a guide repair question
#1
Posted 26 December 2012 - 10:28 PM
I've got a leak, through the bolt which holds the front, outside guide. The outside acorn nut is locked and I'm having a heck of a time removing it to seal the bolt and replace the acorn nut....
Does anyone know what type of bolt head is on the opposite side of the acorn nuts...standard slot or philips, flat or pan...I have a feeling I'm going to be making a tool to access the head without removing the top and the access is a 1/8" slot...ugh.
2003 Ford 250 Superduty Crew.... 7.3L PowerStroke diesel 1970 10" NCO Alaskan Firestone airbags pulling a 18' Silver Streak runabout
#2
Posted 28 December 2012 - 04:22 AM
The front and rear of the NCO's have a pair of guides which align the top and bottom section for raising and lowering. In the CO's they are on the rear only, right behind the hydraulic tubes.
Are you able to grip the bolt on the inside?
#3
Posted 28 December 2012 - 07:56 AM
99 Dodge 2500 4x4 Diesel, 94 CO Alaskan 10', 10 ply BFGs Air bags, VE7YHE
#4
Posted 28 December 2012 - 04:33 PM
the head has minimum clearance and is probably a flathead due to the location inside the guide...I'm pretty sure I could fashion somewhat of an offset ignition driver as was suggested but I don't know if it's slotted or philips...
the aim is for stainless replacements and I think I'm just going do all of them in the spring...
pop top...coming up...you've gotta luv em
I temporarily waterproofed the bolt head by using a single serving cream cheese container...cleaned up....hole drilled in the edge for drainage and installed flat around the bolt head with a little polyurethane adhesive....the white color even matches...LOL
farming ingenuity
