we had a tt once and we had a 40 psi regulator [sp] on the hose
New FWC Hawk Options - Now vs Later?
#121
Posted 09 January 2014 - 12:08 AM
#122
Posted 09 January 2014 - 01:23 AM
I made my own from supplies from the hardware store. After my first trip I found I need to make some changes. I'll do the changes tomorrow and get some picts up on the new one.
FYI - the hose is simple clear hose with 5/8" ID (I think). The new one will have the first section made of PVC and then run to the ground with clear vinyl tubing.
Stay tuned....
2018 Dodge Ram 2500 Quad Cab, 4WD, CTD paired with a 2013 FWC Hawk
#123
Posted 09 January 2014 - 08:36 PM
For a carpet I had something like this door mat. I got mine from the laundry service we uses where I worked. I cut to fit. Just pull out and shake off.
That is a great idea.I use a mat like that in the back of my Ford Escape.
I have wood flooring over the linoleum,but I sure would use that mat if I didn't already have my fix of the floor.
Thanks Bill.
#124
Posted 10 January 2014 - 01:59 AM
Here's picts of my new set up. The vinyl tubing didn't work very well so I made a new one and used a bicycle tire inner tube.
#125
Posted 10 January 2014 - 03:39 AM
School me brother, what's the particular benefit of that set-up as opposed to just using an old garden hose? I'm thinking it will drain much better and take up way less space, yes?
#126
Posted 10 January 2014 - 04:20 AM
Kilr0y,
The garden hose takes up quite a bit of room compared to this (plus I hate garden hoses), especially since I already have a 15 foot potable water hose in the exterior storage box. Plus any type of hose seems to have a memory of the coil when it was stored. The inner tube hangs straight down and perfectly into the grey water container. The purpose of the "T" is to allow more air to enter the system at the top as the grey water drains to ensure it drains fast and completely. The previous version with the vinyl tubing was not perfect but it did drain really fast. Once I trim the top piece a little more it will take up hardly any room too.
I'll report back once I use it a few more times. Time will tell if it's a bad design.
#127
Posted 10 January 2014 - 04:35 AM
Great ideas, thanks. I like the idea that the tube hangs down straight. I use a 5 gallon bucket for my grey water, so this would work great.
#128
Posted 10 January 2014 - 03:37 PM
Yeah the memory of the hose is a pain. I've used a couple different garden hoses and was going to try the vinyl tube but didn't see how it would be better. Right now I'm using a braided 4' stainless water supply line and then bungi it to my tire. It's just the right length for the bucket I use. I do like your idea tho.
Edited by Riverrunner, 10 January 2014 - 03:38 PM.
2022 F350 DRW Lariat Ultimate CC, LB, 4x4, 7.3L
2005 FWC Grandby
2023 Rockwood 2720IK Travel Trailer
#129
Posted 10 January 2014 - 06:29 PM
I don't remember the thread, or the forum, but somewhere I saw a photo of a connection to the sink drain that had two ports. One went straight down for the drain hose, the other went straight up and served as a vent to get faster draining. I am tempted to do something like that.
Edited by Wandering Sagebrush, 10 January 2014 - 06:30 PM.
I am haunted by waters
#130
Posted 14 January 2014 - 06:00 PM
what keeps the bicycle tire from flapping around in the wind and not staying in a bucket?
