If the money thing is worrying you I will share my costs with you so you can get an accurate idea.
-I scored my fridge for $600 (5% off due to a dent in the back) so figure $700 is findable.
-I am running my fridge off 2 gc2 golf cart batteries for a total of 200 amp hours. I got 2 dekas for $460 picked up from a local store.
-I have a single remote 100 watt panel from renogy and their cheap charge controller. The panel was $200 and the controller was $30. I also paid $40 for a 40 ft cable.
You can save some money by just starting with the batteries. This should get you through 2-3 days alone and if you see a 4th day you can run your truck for a few hours to get you through.
Once you get solar consider a "good" charge controller that has user programable, multi-stage charging like a Morningstar. No need to waste money on MPPT just get PWM.
So to summarize you can get started for under $1200 if you go for it but that is about the minimum without finding used stuff.
If all this isn't enough info you can hit me up or wait until I post my "Idiots guide" I'm working on that should help people in your same situation.
Edited by Ethergore, 11 September 2014 - 03:23 AM.
