Ready...
12 replies to this topic
#11 ski3pin
ski3pin
    Belay On
  • Site Team
  • 15,344 posts
  • LocationSierra Nevada Range
Posted 29 November 2014 - 07:33 AM
Great first trip!
#12 ntsqd
ntsqd
    Custom User Title
  • 2,881 posts
  • LocationNorth So.CA
Posted 29 November 2014 - 03:11 PM
For an entirely different need (8' long collapsed telescoping antenna mast) I used 3" ABS with a cap on the front end and a threaded adapter & threaded plug on the other. I used two footman loops per end on the underside of the right side overhang of the camper. Threaded a hose clamp thru both loops and around the ABS pipe. In hindsight I should add a third such mount to the middle of the pipe.
10' is a little tougher. If it would work in the end use I'd go with double the number of 5's and some couplers.
Thom
Where does that road go?
#13 takesiteasy
takesiteasy
  • 2,588 posts
  • LocationMinnesota
Posted 29 November 2014 - 07:37 PM
No name down here that I know of. They use these canopies at swap meets, I did a quick google and there's lots of companies that sell them.
Try:
http://marksbolts.com
Look under shade systems.
I googled swap meet shade and a bunch of places came up. These are sturdy canopies but, like I said, it's a ton of gear. The 10' poles are the toughest to carry. Not the light weight solution. I'll probably throw a long ABS tube on the top or side of the camper to carry them.
Good luck!
Thanks for the info. I just bungie my poles to the yakima rack. Has worked well so far. A tube would be more professional looking for sure.
2011 Tacoma AC TRD
ATC Custom Shell
travelswithrockythedog.blogspot.com
