flinchlock
New price $7500
All Terrain specializes in strong, light weight, welded aluminum frame that are built to survive.
They have been building custom made campers for decades.
We drove from Michigan to California to pick it up due to the fuel savings of the unit.
It has been used 145 nights and is stored in a pole barn when not in use.
It is in excellent shape.
We are vegetarians so it does not have grease smells or stains inside the camper.
It DOES NOT have a fridge. There is space for a fridge and it was factory wired in case one was ever to be installed. We used the area for storage. We used a cooler when we did want to have a cold drink.
Four people can sleep in it. There is a bed for 2 above the cab of the truck. A couch can be turned into a bed for 2. One feature that is absolutely wonderful is that 2 people can sleep on the couches with the top down which we often did after taking a long hike.
There is a stainless steel 2 burner stove
Stainless Steel sink with hand or 12 volt water pump
15 gallon water tank
Monitor panel for water level and battery charge
12 V 100Ah AGM sealed lead battery UB121000 Group 27 bought new 4/23
Smart Battery Isolator (protects electronics)
2 12V USB outlets
Carbon Monoxide & Propane Gas Alarms
16,000 BTU Furnace with Honeywell digital thermostat
5 gallon/20 lbs propane tank with gauge
Cold weather pack for extra liner insulation
Pre-Wired by All Terrain for a solar panel
All Terrain installed 40# lift struts to assist lifting the top
Four mechanical hand crank corner jacks to allow stand alone capability
Windows on every side of the camper with curtains.
Large window above couch can be opened and has a screen
2 powered reversible 3 speed roof vents modified to have 6 speeds to be quieter
Front window facing truck slides opens, allowing a pass through option
Lots of storage under the couches and in built in cabinets
Screen door, and a keyed dead bolt lockable entry door.
4 roof struts to access the roof for boat, canoe, kayak, etc …
Battery connection between camper and truck battery via Attwood trolling motors connectors.
Female on camper cable, male on truck. A new male connection needs to be supplied.
Extras:
Zodi 8170 Extreme Portable 3 gallon Shower
Outback Porta Privy, used when taking showers
Lynx Levelers
Metal Study Step for truck receiver and 2 foot step ladder
Small folding table
25 foot White RV hose
Master Flow portable air compressor for truck tires in rural areas
There is a steel plate included made by All Terrain to be used with an Aluminum truck bed
Located in Southwest Michigan
We are willing to deliver it within a reasonable distance.
We can take PayPal for payment or a cashier’s check.
flinchlock@outlook.com
2 12V USB outlets
Extras:
Lynx Levelers
Small folding table
