Jack
19 years later, Toyota has a true upgrade to the 2nd and 3rd generations and they can now be purchased at dealers. Anyone with experience with a FWC - mounting, mpg, etc.?
Just a note on the Toyota bed bolts mentioned above. I stripped one out on my 09 Tacoma so I found a machine bolt that just fits inside the Toyota bolt hole, I believe it might have been 3/8". I used a high grade steel bolt and secured it with lock washers and lock nut. Obviously you have to crawl underneath to tighten and have someone up above (or use a vise-grip) but mine has not loosened up at all with many years of rough road travel. This would solve the bolt length problem, but probably not the best solution for all 4 attachment points.
