Low cost DIY Lithium camper batteries.
Lithium LiFePO4 LFP DIY Batteries
217 replies to this topic
#201 buckland
buckland
  • 3,080 posts
  • LocationNew England
Posted 15 May 2019 - 05:33 PM
Thanks rruff
I am a noobie with all the self doubt and so am overly cautious. I am getting tired of looking at the battery 95% done sitting on my work bench so I decided to bring it up to 99%!   I reread a few times the direction Rando had given me on wiring and went ahead and attached the two BMS/monitor I have ....I think.... done okay in that I haven't fried anything.
I am at the point where I have the negative wire from the battery management board.... which I believe will be the battery post wire... and the positive battery post wire I think comes straight from the terminal block + (?)
I have to make the two "posts".
If so I am "done" the making and will work on the install. As I have a three week trip coming in July I might hold off and depend on my current AGM set up for the trip.
I have to learn how the solar controller is programed for charging the battery to the right voltage (float and max charge). I am only familiar with how the AGM batteries are maintained. Here are a couple photos.
Lordwoodcraft  instagram        Rob
The only people who ever get anyplace interesting are the people who get lost.
Henry David Thoreau
"Work to achieve not to acquire"
#202 buckland
buckland
  • 3,080 posts
Posted 16 May 2019 - 02:24 PM
Attached the Victron controller to battery and a 90 Watt panel. Set up the iPhone app and connected bluetooth to controller.
Set the battery management to 3.7 V limit for each cell (14.8) and drain at 3.
Set the float on the controller to 13.6 V
Set the Absorption to 14.8 (Not sure ...is this the Bulk charge?)
The battery monitor has not changed readings.
I find it odd that panel is indicating 0 Watts
Attached find screen shots of there Victron  App
Any advice appreciated as at this point not sure what  am looking at.
Edited by buckland, 16 May 2019 - 02:24 PM.
Henry David Thoreau
#203 rruff
rruff
  • 98 posts
  • LocationRuidoso, NM
Posted 16 May 2019 - 04:04 PM
Sorry I can't help you. I haven't even put my batteries together yet, or played with them in some time.
#204 buckland
buckland
  • 3,080 posts
Posted 16 May 2019 - 04:27 PM
That's Ok I'll just be patient and wait for someone who fiddles with this stuff to know. The panel has been in the sun for 3 hours and the battery has not charged a bit....I must have some setting set that is keeping it from happening​. I like the scientific method rather than the method of "push all buttons and see what happens".... I am amazed I got this far!
I also am not sure why I need the two Battery Management systems... maybe that is the cause?
Edited by buckland, 16 May 2019 - 04:28 PM.
Henry David Thoreau
#205 ckent323
ckent323
  • 1,227 posts
  • LocationSolvang, CA
Posted 16 May 2019 - 05:25 PM
Buckland,
The Victron app display shows that the panels are working and outputting voltage (20.85 V).
The battery part of the display shows it is fully charged (13.6 V) and in float mode thus no current is flowing.   If you have a small load you can put across the battery you should see the battery voltage drop and current start to flow.
Did you go into the app settings and make sure the various parameters for your particular  battery are set correctly (it seems so but never hurts to double check)?
whoops, I just double checked the settings you posted
Those do not look correct to me (I use a lead acid battery)  I believe LiFePo4 cells are 3.65 V each.  A 12 V LiFePo4 battery would use 4 cells.
4 cells at 3.65 V = 14.6 V  I think this is what your float voltage should be.
I am not sure but I think the absorption charge setting should be around 14 V
Hopefully Rando or someone else familiar with LiFePO4 will comment.
Since you have the float setting programmed for 13.6 V, the Victron charge controller thinks your batteries are fully charged already hence no current flow.
Edited by ckent323, 16 May 2019 - 06:25 PM.
  • 1
#206 rruff
rruff
  • 98 posts
Posted 16 May 2019 - 05:59 PM
ckent323: 4 cells at 3.65 V = 14.6 V  I think this is what your float voltage should be.
I think I did 3.6v max while charging and they settled to ~3.3v fully charged. That's 13.2v for 4 in series.
Edited by rruff, 16 May 2019 - 06:00 PM.
#207 ckent323
ckent323
  • 1,227 posts
Posted 16 May 2019 - 06:50 PM
are these what you guys are using?
Manufacturer: Guangzhou Fullriver Battery New Technology Co., Ltd.
Model: 32700Fe
Nominal Voltage: 3.2 - 3.3 V
Nominal Capacity: 5400 mAh
Energy density: 125 wh/kg; 300 wh/l
Charging current: 3.3 A Max.
Discharging current: 9.9A continuous
Operating Temperature:
Charging: 0° to 45°C
Discharging: -20° to 60°C
Cycle Performance:
>2000 (80% of initial capacity at 0.2C rate, IEC Standard)
2 times more than NiMH and 10 times more than SLA
Dimensions (DxH): 32.3mm (1.27") x 72.0 mm (2.83")
I think these are 3.65 V per cell peak voltage and 3.2 V - 3.3 V per cell nominal voltage.  (page 1 - Post #4 in thread).
Anyway going back to the first few pages of the thread I see that rando chose to derate the charging to 90% to 95% of SOC and limit charging to about 3.2 V per cell (page 8 - post # 72 in thread).  No criticism just an observation - I am no expert on these.
Probably best to ignore my float voltage setting comment - my comments were simply intended to stimulate your thinking about the details of the settings.
Edited by ckent323, 16 May 2019 - 06:53 PM.
#208 buckland
buckland
  • 3,080 posts
Posted 16 May 2019 - 06:54 PM
Okay.. the other strange thing is the battery balance monitor (not Victron) is indicating my battery only had 13.13 V
3.32, 3.28, 3.27, 3.26.
I just flipped on the balancer and I believe it corrects at .05 per 10 minutes. ? Will leave it on for a couple hours and see what happens.
Update after three hours .... no change in any cell all exactly the same..... hmmmmmm
Also wondering why the BMS says 13.11 V... the Fluke says 13.13 V and the Victron app says 13.6V. ?
Edited by buckland, 17 May 2019 - 05:37 PM.
Henry David Thoreau
#209 rando
rando
  • 1,638 posts
  • LocationColorado
Posted 18 May 2019 - 11:58 PM
Sorry for the delay on this - I am off on a field project.
Your balancer set up looks to be correct - and the cells are in decent balance for not having been actively balanced previously.   If you press the balance button on the balancer you should see a little scale icon (aka a balance) appear by the higher voltage cells.   Just be aware that this balancer only draws 0.1A from the cells and is therefore it is SLOW to balance such a big battery pack - as in it could well take several days or longer to bleed down the higher voltage cells.   As long as you see the scale icon though it is working.
There is definitely something not quite right with your solar system.     It almost looks like it is not connected to the battery and that it is just pulling the output up to the float voltage.     I also don't see in the photos how you have the BMS circuit board hooked up to the batteries overall -ve and +ve terminals (the two end most screw terminals on the screw terminal block)?    Has that been done?
For now you can just hook the Victron battery connection directly to the pack (without going through the BMS circuit board) and it should work for now.   But you should eventually hook it up through the BMS at some point as this provides an extra level of protection if something were to go wrong.
For the charger set points - lithium batteries don't like to be float charged, so set the float voltage to be just a hair above the fully charged battery voltage - say 13.3V.   This way any loads will pull of the solar system first, but you won't really be float charging the battery.     I set my bulk and absorption to be pretty low  at 13.8V as I rarely use the whole battery capacity and I would prefer it to last longer than to get that last 10% of charge.   Make sure equalization and temperature compensation are turned off.
2016 Fleet Flatbed
2016 Toyota Tacoma
#210 buckland
buckland
  • 3,080 posts
Posted 19 May 2019 - 05:56 PM
Quote and answers:
 The battery management board (not monitor) is hooked up exactly as the monitor BMS (why do I need both? do they do the same thing?)The board however has the neg- 10 gauge wire soldered to the board. That runs to the Victron battery neg.-. I followed your directions for balance wires that clip in with plug and go to the terminal board exactly like yours except the last balancing black wire from the clip goes to the negative on the terminal and orange to the positive. the other three are in-between the four packs.
On BMS monitor I set the drain minimum V to 3.0 and the top at 3.3 V. I have hit balance and it ran for hours w/o anything changing.
I have the panel connected to the PV on the Victron. I installed the Victron iPhone app and it shows panel and battery. I have not figured out all the settings. I did set the battery type to LiFePo4. I set the float to 13.6 .... I can't find anywhere where it sets Bulk. The last question you ask I thin I answered above.
Both BMS boards are attached. The neg soldered to the board goes to the Victron battery negative - and the positive on the terminal block to the Vicvtron Pos.+
I will change the float to 13.3. I do not know how to set the Bulk on the Victron but I think I have seen the page with the absorption setting on the Settings page. I will photo that here next. Yes the equalization and temp compensation are off.
Thanks again for your guidance. It is getting exciting to think this might just work! Also great not having to maintain the battery during cold season. I believe you said I should bring the battery down 3 V per pack for storage and forget about it until Spring.
Edited by buckland, 19 May 2019 - 05:58 PM.
Henry David Thoreau
Also tagged with one or more of these keywords: Lithium, LiFePO4, LFP, DIY, Batteries
