Story: The Camper That Fell Off
50 replies to this topic
#11 Casa Escarlata Robles Too
    C'est la vie
  • Site Team
  • 9,295 posts
  • Locationmonterey bay area
Posted 05 December 2018 - 08:44 PM
Great story and it turned out OK.
You would think he would have missed
the camper when it slid off.
Sure would like to know about the turnbuckles.
How did all 4 come off and not be noticed?
All worked out for him.
#12 PackRat
PackRat
  • 680 posts
  • LocationNovato, CA
Posted 06 December 2018 - 06:46 PM
If you are using standard turnbuckles, you probably need only one or two runs out there on the highway or some uneven roadways to "set" your camper. Then make any adjustments necessary (usually tightening) and then use WIRE threaded through and around the turnbuckle and the eyebolts to keep them from loosening. I have seen turnbuckles with hex nuts you tighten down onto the turnbuckle from the outer threaded rod which should be checked periodically, but I have neveer seen turnbuckles with an additional INTERNAL hex nut that can be used to tighten the outer hex nut, the turnbuckle itself and the internal hex nut against one another.
This is a weak spot in the design if they are not checked often enough. Especially if you are going off-road or are on some dismal paved roades.
1988 Ford F-250 HD Lariat 4x4 8 Ft. bed
1976 Alaskan 8 Ft. CO camper
#13 Ripperj
Ripperj
  • 239 posts
Posted 06 December 2018 - 07:08 PM
How can you lose a 1/2 ton (or more) camper off the back and not know? Just the fact that your rear window is no longer blocked would be a big hint :)
  • 1
#14 Casa Escarlata Robles Too
    C'est la vie
  • Site Team
  • 9,295 posts
Posted 06 December 2018 - 10:59 PM
This may not be true for everyone but
I have driven my ATC Bobcat over 50K
and never had to re tighten the turnbuckles.
Granted I don't travel 4x4 roads but I have
traveled some pretty rough diet ones.
I still check them though.
Just saying.
My thought also about the camper coming off
and not noticing the extra light from the rear truck window.
#15 craig333
craig333
    Riley's Human
  • 8,022 posts
  • LocationSacramento
Posted 06 December 2018 - 11:29 PM
I can see it. Its a tough dangerous road. You are keeping your eyes on the road lest you hit the valley floor prematurely.
  • 1
#16 BillTheHiker
BillTheHiker
  • 307 posts
  • LocationBoise, ID
Posted 07 December 2018 - 04:38 PM
Explanation is in one of the article's comments:
Roger, I tightened the turnbuckles before I set off but I guess the jolting and shaking loosened them up quickly. I should have checked again half way up. I am going to get some locknut system as the consequences of these turnbuckles slacking off are catastrophic.
#17 PackRat
PackRat
  • 680 posts
Posted 07 December 2018 - 08:02 PM
While you may not lose your camper, as each turnbuckle slacks off, the forces it held in check are passed on to the others in a domino effect and may end up ripping out floor panels! Secure them and add checking on them to your check list to prevent movement of the loss of the camper in the extreme case.
#18 theway131
theway131
  • 42 posts
  • LocationSan Luis Obispo County
Posted 29 December 2018 - 08:30 AM
The turnbuckle and thru bolt system with backer plates from FWC a very weak and flawed system. I’ve deformed two different trucks beds and almost lost my camper on 3 occasions! When the bed deforms the turnbuckle gets loose and all hell breaks loose. It can happen from one hard bump.....Stoked they were able to find such good help out on the trail.
#19 EDR
EDR
  • 177 posts
  • LocationSE WA
Posted 04 January 2019 - 04:11 PM
https://www.truckcam...-that-fell-off/
A story worth reading.
I’ve read the advice of fellow campers on this site many times, but it never hurts to mention it again - be sure to regularly check your turnbuckles!
2007 FWC Hawk
#20 Josh41
Josh41
  • 152 posts
  • LocationMassachusetts
Posted 04 January 2019 - 04:25 PM
I ordered Torklift Derringers, yet to install.
Nissan Frontier 2016 CC LWB, 2" lift, tires, airbags and other stuff
FWC Fleet
Summers Off
