Alternate Backup Camera F-250
2011 Ford F-250 camera backup tailgate remove tailgate
26 replies to this topic
#21 Kispiox
Kispiox
  • 204 posts
  • LocationPacific North West
Posted 26 August 2013 - 12:50 AM
Thank you photohc and all! I have removed and remounted the ford tailgate camera into the sheet metal just above the license plate and below the camper door threshold. My camper will pretty much live on my truck but I did it so that the process can be reversed if I want to sell the truck. My experience with third party cameras in AK,BC and PNW in cold, hot & wet climates is not good. Having said that, I also have no experience with Ford stock cameras, so the jury is still out, I took some pictures, so will upload them when not mobile. Thank you again.
#22 Marshfly
Marshfly
  • 51 posts
Posted 29 August 2013 - 03:32 AM
Since you took the time to figure out the wiring, would you mind posting what is what and the part number for the harness?
2014 Ram 3500 Crew 4wd Cummins, 2013 Lance 855
#23 photohc
photohc
  • 253 posts
  • LocationSo. Calif.
Posted 30 August 2013 - 11:40 PM
The wiring loom that goes from the OEM camera and out the tailgate is:
BL3Z14A411A
WIRING - MAIN - ELECTR.OPER. M  Price: $20.77
This is a ford part number ordered through their online site. The pinout for the camera connection I will post next week when I get home to look it up. Thanks.
Ford 2018 F250 FX4,Lariat, Gasser. FWC 2013 Hawk W6QN (formerly KH6FBU)
#24 Kispiox
Kispiox
  • 204 posts
Posted 04 September 2013 - 03:21 AM
Okay, so pulled the Ford camera from the tailgate handle and removed the pigtail.  With camper in place dropped the spare tire drilled a hole in the sheet metal to accept the camera lens and also the fasters (see picture).  Picked up a piece scrap of 1/2" acrylic and drilled a hole in in to accept the camera lens (see picture).  I roughed up the acrylic with rough sand paper a glued the camera to it.  I use marine Sicaflex which can be purchased at a marine hardware store.  I is better than silicone but can be taken apart if the camera ever needs to go back in the tailgate.  If you are not ever going to put the camera back into the tailgate I would use Dow 5200, but know it is permanent.  So, after glue sets up.  I drilled and tapped three 8-32 polished hex oval head stainless steel screws to hold in place.  Works Great,... just like original because it is original with the exception of a slightly different viewing angle which frankly might be better in my humble opinion.
#25 Kispiox
Kispiox
  • 204 posts
Posted 04 September 2013 - 03:22 AM
DSC04619.JPG DSC04621.JPG Here are two more pictures...
#26 photohc
photohc
  • 253 posts
Posted 04 September 2013 - 05:00 AM
Nice job Kispiox. I may do that to mines as well. As for my previous post, I looked up the pin-out for my 2013 F150 FX4 and they are as follows:
#1 VT-BN (wire color violet/brown) 12v+
#2 not used
#3 BRN-VT 12v-
#4 WT-GRN Video +
#5 BK-GRN Video -
#6 not used
Depending on your truck, year, etc. It may vary. Best to use a volt meter to check for the 12v+ and ground. The other two would be the video connection. Just connect the camera and look for the video. If no display, reverse the connection. It should work with just about any third party cameras sold on Amazon. (of course, not the same quality).
Edited by photohc, 04 September 2013 - 06:09 PM.
#27 Kispiox
Kispiox
  • 204 posts
Posted 18 April 2014 - 03:12 PM
ROAD TESTED!!! I now have some miles on the above camera install now. I am retired and have been traveling non-stop since the install. It has been to Northern British Colombia and fished up and down the Skeena Drainage, on a ferry from Prince Rupert to travel the length of Vancouver Island, to SoCA, back to the Olympic Peninsula (almost solid rain and humidity for three months and a little snow too) then to Death Valley (ahh, dry again). It has operated flawlessly. No clouding, no rust around the edges. Haven't touched it. That's as it should be.
Also tagged with one or more of these keywords: 2011, Ford, F-250, camera, backup, tailgate, remove tailgate
