What brand is the 150 Bill? Do you like it and the Renogy? I think 250w is great if you are running a compressor fridge and charging computers and watching TV. Hard to have to much solar.......
Solar Panel / Yakima Tracks
#31
Posted 11 May 2016 - 08:19 PM
2018 Ford F-250. Customized Bundutec Sable
#32
Can't go wrong stealing Bill's ideas...lol
#33
Posted 28 May 2016 - 05:11 PM
I am working on a Yakima Tracks solar install. 60" seems to be the longest track length I can find on the Yakima and REI website. Is it possible to source longer tracks or can you connect multiple tracks together?
1997 OBS Ford 7.3 DSL 4x4
1985 Four Wheel Keystone
#34
Posted 28 May 2016 - 06:26 PM
Edit: yes they are connected.
I am haunted by waters
#35
Posted 29 May 2016 - 02:10 AM
I believe mine are connected. I'll check and correct if that's not the case.
Thank you for checking, looks like I better get some ordered before they go off sale at REI!
#36
Posted 01 June 2016 - 05:42 PM
I used the z brackets from Renogy solar to add my solar to my tracks.
It is nice if you buy a panel long enough to cover the tracks otherwise you will also need some other hardware like Bill has.
Mine has worked fantastic. The panels have not blown off and since it's a hard panel, I hope that it should work for many years to come.
Dr. J, great setup. I've been reading some of your solar and electrical post. Its been very helpful. Thank you. What type of MPPT controller are you using? Do you have any issues with raising the top? Do you have 40 lb external struts?
2003 Tacoma 4X4 - 2007 FWC Eagle shell
2006 Tundra Double Cab - 2015 Hawk - side dinette, silver spur interior
#37
Posted 01 June 2016 - 08:05 PM
MPPT TRACER 3215RN Solar Charge Controller 30A 12V 24V EP https://www.amazon.c...i_e-Ztxb5EER7NW
The panel is heavy and I increased my lift assists to 60 lbs. That seems to work just right.
2015 Silverado Crew Cab Duramax and 2015 Front Dinette Grandby
One can change the world, it only requires kindness
http://www.truckcamp...g-family-earth/
#40
Posted 09 June 2016 - 09:45 PM
Here is the finished product! Thank you to everyone here, super helpful!! It worked swimmingly over Sasquatch Music Festival at the Gorge. It didn't fly off in the Gorge, and we had a full battery at all times.
Riley
Hey rilcombs,
what size angle aluminum did you go with? 1.5" x 1/16 or 1/8?
http://www.homedepot...02617/204273956
I am also considering the stick on mounts using 3M VHB, thus freeing up my slider tracks for any type of gear/footpad arrangement, as the panels would not be in contact with the yakima tracks at all ( i am looking at 100w panels from renogy which are 47" long, fitting inside the 60" spread of the yakima tracks). Spendy though at $160 for 2 panels worth of brackets
http://www.amsolarrv...panels/35rocker
Also tagged with one or more of these keywords: 2014, raven, solar, panel, renogy, roof, install, yakima, tracks
