My setup is a 2010 Tacoma with Eagle FWC. 3" lift total with this setup.
I'm always at the GVW but since I can't afford a new truck right now my setup is the following for FULL TIME install of the FWC. I'll hopefully replace this truck in another 5 years.
This setup is also designed for 4Wheeling with the camper installed to boondocks sites both rock crawling and desert. It's not setup for mud but I've done a few trips successfully with no winch.
If I remove the FWC, it drives terrible but that's not too often only when I need to do some home depot type runs or bring a motorcycle to a shop or something.
Hellwig Progressive Spring Pack for FWC
http://www.hellwigpr...-products/4231/
Roadster Active Suspension Kit for Sway:
http://www.activesuspension.com
ICON Hydraulic Bump Stops
http://iconvehicledy...top-system.html
ICON Stage 1 Front
http://iconvehicledy...tem-stage1.html
Total Chaos UCAs
http://www.chaosfab....-Kit-96504.html
