Last December I decided to downsize from a 2500 Silverado to a new 4x4 Chevy Colorado 5’ short bed, crewcab with the new 2.8l DuraMax diesel.
I knew I wanted a FWC or ATC, but not really the short Swift, but rather the longer Fleet and because of the Colorado’s higher bed sides, making another forkliftable riser to fill the gap between the bed floor and the bottom of the camper and support the 21” that was behind the bed floor was in order.
The build for the Silverado’s forkliftable riser for my Kestrel is here:
http://www.wanderthe...ge/#entry124218
I had planned to modify the original riser for the Kestrel to fit the Fleet, but the first person that saw the camper wanted the riser along with the camper, scraping the box he had made in his truck for the Kestrel.
The design for a new riser was easy, pay attention to keeping the weight down and maintaining the longitudinal support .I also added in a spacer bar that is bolted in for the unequal height of the Colorado’s bed and unlevel tailgate (or without the tailgate). Unbolting the spacer also would allow the camper to fit any late Silverado if I decided to change trucks again later and not have to re-invent the wheel.
Having done literally over a dozen trucks for carrying service bodies or campers ( or swapping between them), I knew the Colorado would need air springs to go between the full load of the camper and when it was empty, and also replace the shocks with adjustable ones for the same reason. Back in the first of May I ordered and installed the Air Lift ride control air bags and the wireless controller and on-board compressor. The Rancho system that had worked so well in the past had been discontinued and Rancho hasn’t made the 9000s yet for the Colorado… L , So I decided to wait to see what may become available after the camper was fitted.
Jumping forward to last the end of last month, I had my appointment to load the camper at American RV Company., I had done all the tiedowns points in the truck and electrical, and had a couple of different sets of Fastguns and varies quick links and hooks for whatever my needs might be.
