2015/16 Grandby Porch Light
31 replies to this topic
#1 pawleyk
pawleyk
  • 190 posts
  • LocationReno Nevada
Posted 23 December 2016 - 12:44 AM
Hey guys,
The rear porch light on our new Grandby is giving us trouble. Its started out just taking a while to "warm up" to full strength, but now it simply puts out a meager glow no matter how long its left on.
It is an amber LED, one of those flat paddle looking ones. It doesn't have the same connector as the bulbs on the inside, however. It uses a standard, old-school RV socket.
Anyone know where I can get a replacement bulb, or if that's even my problem? I know the LEDs are supposed to last forever, so maybe I've got a bad connection somewhere in the housing?
I have tried the obvious and wiggled the thing in the socket, no luck though.
I've also looked all over Amazon and the web, but can't seem to come up with anything quite like I've got back there.
Like I said, Amber LED. Pancake shaped. The lens is clear.
There could obviously be worse problems, but we really grew to like our little amber light out back.
https://www.instagram.com/kp.pawley/
A farm boy and a Chevy truck take a long drive.
KI7AMV
#2 longhorn1
longhorn1
    Ouch, that stings!
  • 2,826 posts
  • LocationCarmel, Indiana
Posted 23 December 2016 - 01:41 AM
I thought there was something wrong with ours. I turned it on and no light, turned it off and back on and it came on. I will have to check it out when we load the camper up in March. jd
Edited by longhorn1, 23 December 2016 - 01:34 PM.
http://texaslonghorns01.blogspot.com/
Ford F-250 Long bed, 2014 Grandby
#3 nikonron
nikonron
  • 578 posts
  • Locationowensboro,ky
Posted 23 December 2016 - 01:46 AM
Give me a shipping address and I'll send you a new one. I removed mine and put in a white LED.  Ron
  • 1
#4 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,594 posts
  • LocationNortheast Oregon
Posted 23 December 2016 - 03:23 AM
And that's why people love WTW! Well done nikonron!! :)
I am haunted by waters
#5 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,594 posts
Posted 23 December 2016 - 03:28 AM
Have you removed and reseated the LED a couple of times. We had a similar issue with our Northern Lite. I swapped the 'bad' LED with one from another light, and then they both worked.
#6 pawleyk
pawleyk
  • 190 posts
Posted 23 December 2016 - 04:42 AM
PM sent.
Thanks man, that's awesome!
KI7AMV
#7 pawleyk
pawleyk
  • 190 posts
Posted 23 December 2016 - 04:43 AM
I did actually try taking it out a few times. Tried shining up the contacts and just generally jiggling things around too.
No dice. Hopefully it's just the bulb.
Edited by pawleyk, 23 December 2016 - 04:43 AM.
KI7AMV
#8 WyomingJames
WyomingJames
  • PipPip
  • 14 posts
Posted 23 December 2016 - 07:24 AM
You might check and make sure the light fixture is getting a good ground connection!
#9 PaulT
PaulT
    Need gumbo
  • 2,612 posts
  • LocationHillsboro, Oregon
Posted 23 December 2016 - 07:44 AM
If you have the awning with awning light similar to the porch light, swap the led bulbs between them. If the problem moves, it's the bulb. If not, suspect the fixture.
#10 camelracer
camelracer
  • 960 posts
  • LocationGoleta, Ca
Posted 23 December 2016 - 07:49 AM
I had a problem with my rear porch light and it turned out to be a dirty switch. I got a spray can of contact cleaner from Radio Shack and it seems to have fixed the problem.
2002 Fiat 2500 CTD 4x4, FWC Grandby 1951 Willys CJ3A
