Is it just me or is there an obvious generational gap in this thread?
"Gnarly" and "Super sketch!"
Personally, I had a little bit of a flashback when I saw gnarly.
Jiminy crickets!!
Posted 01 April 2017 - 05:15 PM
Jiminy crickets!!
Posted 01 April 2017 - 09:09 PM
Looks like its just you.
Posted 15 April 2017 - 03:55 PM
I'm sure it's the joy of Chinese manufacturing. Poor quality casting.
'08 Dodge 3500, '11 ATC Cougar
Build Thread: http://www.wanderthe...r-build-thread/
Blog: https://raftercexplo...s.wordpress.com
Posted 15 April 2017 - 03:58 PM
Was the cause of the step failure ever determined? I believe the broken step was to be sent to FWC for evaluation.
Phil
Posted 16 April 2017 - 02:57 PM
Do the bolt holes match the OEM steps? Do these have higher weight ratings? I use my steps a lot and if these are better, I'm replacing them.A raising of hands isn't accurate being that most don't use their steps often.
I'm not taking any chances. Just ordered 3 of these: http://www.ebay.com/...=STRK:MEBIDX:IT
Cant stand the cosmetics of the OEMs anyway.
Posted 16 April 2017 - 03:33 PM
I'm not sure about the max load ratings but I would think that if they are designed for the foot, they would be sufficient unless your feet themselves are overloaded .
The holes match up perfectly with OEMs and the holes are a camel hair smaller. The overall thickness of the part is a bit thinner .... but being stainless steel, I would think the same thickness isnt needed anyway.
They are highly polished and other than being a little thinner in construction, they tilt down about 5 degrees when in down position.
I recommend the changes .... especially when I can vision torn muscle/tendons hanging out of my calves otherwise.
Our campers are made to enjoy the outdoors .... not cause for life flight while out there.
Posted 16 April 2017 - 03:58 PM
Again, I must be the odd-man out...one step breaks and the sky is falling, jeez...death and/or dismemberment to follow..is there anyone else with a broken step on a FWC?
Plus anyone who has climbed anything knows to not rely on a single point of contact..minimum two points of contact is the rule. The OP didn't fall or fillet his leg because he had a second point of support..since he seems to be a rock jock, that did help
Nothing wrong with replacing steps with the spiffy stainless steel ones....arguably they look better [don't like the downward angle when open....
One last time...why did the step break? Has there been any other steps on FWCs that broke?
Phil
Posted 16 April 2017 - 05:52 PM
Wallow ... why do you want to know why the one step broke so bad if you have faith in all of the others out there, including yours?
Posted 16 April 2017 - 06:38 PM
It is always about probability. Nothing and I mean nothing is 100%. So what assumption of risk is an individual FWC owner willing to take? Think for a moment that there must be thousands of these steps that have been in use for some time and if only one has failed [nobody knows how many but we only have this one report] what is the real world probability that my step or your step might fail? Then overlay what is the consequence of such a failure if in fact a person is prudent and does not try to balance on one step [Can anyone really balance on one of these steps?] without another handhold in case you slip off the step or the step pulls out of the camper wall or the step breaks.
Look I am all about risk management and the follow up, assumption of risk. But like Henny Penny, one leaf, or in our case one failed step does not constitute a real threat or real probability of risk.
Why am I curious about why this single step failed? Just my analytical nature; 'why' [one of the 5 "Ws"] has always been the question I ask first. In the end I am pragmatic and refuse to run scared...that does not mean I will not run if I have to!
Enjoy those new steps you installed; they do look good. And if it brings you peace of mind, so much the better.
Phil
Edited by Wallowa, 16 April 2017 - 06:39 PM.
Posted 16 April 2017 - 07:16 PM
I'm also curious if there has been any determination on why the step failed. I have inspected mine and see no obvious flaws but it would be interesting to know if this is a systemic problem or an isolated incident.
