an acquaintance mounted his rotopax here. I like the use of that space.
Posted 07 February 2018 - 08:31 PM
https://no-destination.org/ .:. https://razorgirls.org/
2014 Tacoma DCLB + 2015 FWC Fleet
Posted 07 February 2018 - 08:35 PM
I like that too... is that a through bolt or did they get lucky with hitting the framing?
Posted 07 February 2018 - 11:05 PM
This is a great use of space.
2015 Chevy 2500HD 4x4, Double Cab, Long Bed
2016 FWC Grandby
Posted 07 February 2018 - 11:09 PM
I've been brainstorming and reviewing others approach to mounting a shovel. I came up with this, which was easy to do.
I'm probably overly conservative, but in bad winds would it be enough to snap the top of the shovel off? I'm uncomfortable with the potential to litter a piece of metal onto a roadway that could cause an accident for someone else. That said, seems some have managed with bungies or other strap devices and been ok...
edit: I have no idea why the photos are rotated 90 degrees... nor how to fix it. :-\
Edited by doc, 07 February 2018 - 11:12 PM.
2016 FWC Grandby
Posted 08 February 2018 - 04:45 AM
I like that a lot Doc! Thanks for another solution and project!
Posted 08 February 2018 - 01:37 PM
If you're worried about the wing nuts working loose there's an old desert racer's trick that will stop it. Drill a small hole at the tip of the ears of both wing nuts. Then get a coil spring that will *just* stretch enough to reach from hole to hole. The trick is to hook the spring in the hole of the ear that has to TIGHTEN in order from the spring to relax.
Posted 08 February 2018 - 05:01 PM
Mine is similar to what others have done with the AT can. Attached to the jack bracket and also bolted through in the propane tank compartment. Kinda had to see the attachment on the bottom but there are 4 more bolts underneath.
Edited by JCatt, 08 February 2018 - 05:50 PM.
2014 FWC Hawk
Posted 10 February 2018 - 03:33 PM
Very timely post--I'm about to add a custom aluminum box and a 2-gallon Rotopax to the back of my 2016 Fleet and need to fabricate and install a bracket. See my attached photo.
The cross bracket (yellow box on photo) will span from the grab handle to the jack bracket. I'm planning to attach the bracket using some combination of existing mounting points - grab handle, steps, jack bracket mounting screws or jack mounting holes. The bracket will be made from either 3/16" or 1/4" inch aluminum plate.
The steps are in the way and will be removed and the mounting holes will be covered with a plate or incorporated into mounting the bracket. I can't see how they are mounted because of the propane box. The steps on the left side of the camper are attached using bolts with backing washers.
So, some questions:
Just FYI, the aluminum dry box will be mounted vertically next to the door using this cross bracket and will also sit on a lower bracket bolted through the floor of the camper. The Rotopax will be mounted on the cross bracket to the right of the box. The box (on order) will be 35"L x 13"W x 10.5"D and will weigh about 17 lbs dry and will be used to store about 10 lbs of light weight but bulky items like life jackets, Alpacka raft, etc. The Rotopax will be empty 95% of the time and used primarily to fill the water tank when I can't use a hose or when I need to filter water to add to tank.
Many thanks, in advance, for your help.
Edited by Redfish, 12 February 2018 - 05:32 PM.
2016 Tacoma 4x4 V6 SR5 AT
2016 FWC Fleet
Posted 11 February 2018 - 07:56 PM
Posted 11 February 2018 - 11:19 PM
Redfish, the bolts for the steps go all the way through to inside and have nuts on the back. Ron
