Four Wheel Blazer Pop-up, Finally found one
#141
Posted 17 November 2018 - 10:17 PM
#142
Posted 18 November 2018 - 04:23 AM
Red Cone is one terrifying trail especially the last down hill section.
You betcha. I think the wrinkles are finally out of my seat cover from that one. I knew it was hairy going in. I read up on it through my trail guide book and multiple trail websites. I definitely missed my granny low 4 speed from my old K5 on that downhill, but the deeper low range in the 241 made up for part of it. Plus not having to put my left foot on the clutch pedal allowed me to stand (and I mean STAND) on the brake pedal with both feet.
#143
Posted 18 November 2018 - 06:54 PM
Thought of going Hydraboost? The Bronc-up came to me with it and being able to easily modulate between gentle braking and locked-up on 37's with low pedal effort sold me on them. Had it installed in our CTD and that has made panic stops much more easily managed. Am thinking to convert the '73 SB-SS using CUCV parts.
Edited by ntsqd, 18 November 2018 - 06:56 PM.
Where does that road go?
#144
Posted 18 November 2018 - 11:53 PM
Already have the parts to do so. Actually, I had them before the Red Cone trip and wanted to kick my own tail for not doing the install at that point.
To do the full swap you need the brake pedal too. The hole for the pushrod is not in the same spot as vacuum systems. Mine will probably go in at the time of a big block swap as it will be easier to do then.
#145
Posted 20 November 2018 - 05:06 AM
I believe the Denver/Phoenix K5 with pop top and cummins was done in a shop in MT if i remember right years back as i saw the pics online. Trying to find it online is kicking my butt currently.
#146
Posted 26 November 2018 - 03:48 AM
Back on horsepower front. The 454 has landed. The guy I bought it from delivered it over to my buddy's house Friday night. I have a laundry list of things I need to facilitate the swap but it's pretty manageable. Can't wait to get the rat in it's new home.
#147
Posted 26 November 2018 - 04:17 AM
#148
Posted 01 December 2018 - 05:23 AM
My buddy degreased the engine today. Plugs looked good, no oil deposits or any deposits for that matter. He did find somebody had the intake off at least once and broke a corner of the upper plenum. Good news is he has 2 intakes in stock in his spare pile.
#149
Posted 01 December 2018 - 02:54 PM
Russ
#150
Posted 07 December 2018 - 04:00 AM
Bet your pretty jazzed zoomad, we had a 7 liter in a class B Roadtrek definitely had the power. I had to pull the intake due to a bad gasket problem GM had. Saw it on a V6 motor also. Coolant to oil cross contamination. That might explain the reason the intake was pulled, I went with GM replacment gaskets they upgraded the gasket to fix the problem. One things for sure the new motor is gunna fill the engine compartment:)
Russ
I'm jazzed for sure. The L29 is an great engine overshadowed by the LS engine family and the bigger brother 8.1. As far as installing into a Squarebody, it's a bolt in affair. No engine mount adapter brackets like I had to use putting the 5.3 in there.
The engine will be completely resealed front to back, top to bottom with Fel-Pro seals and gaskets. It will be sealed tight.
The fat block will fill the bay more, but the nice thing is there is lots of room still.
The hunt is on for the NV4500 trans though. After taking some measurements on my existing 700r4 to t-case adapter and my buddies nv4500 equipped 89 Suburban, the overall length from bellhousing face to the mounting surface of the t-case is the same length at 27 3/4". Meaning, I can install the manual and not require any driveshaft modifications over what I have now. Added bonus will be the improved low gear for crawling and better gear splits.
Also tagged with one or more of these keywords: K5, Blazer, 4wc, 4wheel, FWC, pop-up, camper, crawlabago
Trucks, Campers, Gear Forums →
Gear Exchange →
2011 FWC Kestrel $16,800 Akron, OHStarted by Smorgash , 15 Apr 2024 Kestrel, FWC, Four Wheel Camper and 1 more... |
Gear Exchange →
2009 Eagle Four Wheel Camper Madison WisconsinStarted by WiscoK , 10 Apr 2024 truck camper, FWC |
Gear Exchange →
FS: 2023 FWC Project M for 5.5' Full Size Beds - $14,000 - Colchester, VTStarted by danruss , 06 Apr 2024 fwc, project m, tundra, 5.5, 2023 |
Gear Exchange →
For Sale: upgraded 2001 FWC EagleStarted by Wildcat , 26 Feb 2024 FWC, Eagle |
Gear Exchange →
2001 Toyota Tundra W/ 2006 Four Wheel Camper HAWKStarted by carlajuliett , 21 Feb 2024 forsale, toyotatundra, FWC, HAWK |
2 user(s) are reading this topic
Facebook (1)
