The camper battery is hooked up to the truck battery w/a Aopec isolator. installed by ATC:
http://www.aopec.cn/...w.asp?pro_id=17
I un hooked all cables to the battery: voltage was 12.71, 12.81
I disconnected the two leads to the solar controller and hooked up meter for resistance test between the ground wire from the solar panel to the battery and the reading fluxuated between 2-3.
(My meter manual say "the resistance is usually 1 to 0.2 ohms for a standard pair of test leads.)
these are the current readings with everything connected:
battery 13.44v
solar in : 20.81
to battery from controller: 13.17
now to see what happens when the sun gets up high and the outside temp rises....
Now after being in the sun for about an hour, 10:00AM
the solar in reads 13.95
controller to battery 13.85
battery 13.7
10:51Am..... 88F temp outside
On for about an hour here are the readings now
controller
solar 14.62
to battery 14.45
camper battery 14.6 v
thanks for your time.
Edited by 5outta6, 03 September 2019 - 05:54 PM.
