Which air bags to buy?
#41
Posted 05 April 2009 - 09:20 PM
My question here is, is it normal for leaf springs to develop memory like this? I'm supposing suspension air bags will be the cheaper fix for this as opposed to getting another set of leaf springs. Also, I have a lot of sway with that camper on. Do the airbags help with that? Anything appreciated.
Hayduke
#42
Posted 05 April 2009 - 09:55 PM
I did hear of a shop connecting the bags to one valve, which you don't want. If air can flow between bags, when you lean it will make it worse. Make sure they are individually adjustable with two valve stems.
Now, just roaming around in a stock Land Cruiser (not stock for long though... bawahahha [evil laugh])
#43
Posted 05 April 2009 - 10:52 PM
It's appreciated. Thanks for the info. I'm leaving for a 9 day round of Eureka/Racetrack/Hunter Mt./Saline Valley on April 10th with my 8 year old daughter. I'll have one more trip leaning to the left before ordering some bags.
Is anyone else gonna be skulking around out there during this time? Let me know so I can look for you.
Hayduke
#44
Posted 06 April 2009 - 01:51 PM
bsharp in Santa Cruz,
I think I might know you from past. I work in fire department in Aptos. I'd like to see those airbags. My truck has been leaning to the left for several years and need to address the situation. I'm in a white 99 tacoma w/fwc on it. Leaving for Death Valley in a week w/ my 8 year old daughter. Did you do the install? and where'd you get the bags?
Take Care
Hi Hayduke,
More than likely we have crossed path, I'm an old AMR employee and still have a couple of friends at your dept. Anyway, your welcome too check the airbags out, I'll be starting a 4day this Tues. I bought the bags from the Suspension Connection online, they are currently 260.00. I also had Big O on Water St do the install, I don't remember the price but it was reasonable.
As was mentioned one of the advantages is being able to individually adjust each side, eliminating leaning on the heavy side where all the appliances are. Incidently I had the same problem with the leaning in my VW Eurovan Camper that I replaced with the 4WC.
Will, 2019 Ford F150 with a 2022 Hawk
#45
Posted 06 April 2009 - 02:48 PM
I work at the Simpkins Swim Center on 17th Ave.
I have an AT Panther on my '02 Tundra. I'm not using bags, I'm using a different system http://www.activesuspension.com/ . Check it out. It's amazing how well it works. You can have it installed locally, about 5 minutes from the swim center.
If you're interested in seeing how mine look/work let me know. I have the truck at work most of the time.
Clark
2002 Tundra 4WD Limited...TRD package... limited slip... slight lift... custom built ATC - first one sold.
https://www.allterra...attie_Page.html
#46
Posted 06 April 2009 - 11:44 PM
#47
Posted 06 April 2009 - 11:54 PM
CB
#48
Posted 07 April 2009 - 01:40 AM
Just my comments,
Darryl
#49
Posted 07 April 2009 - 07:48 PM
Hayduke (aka Steve B.)
#50
Posted 08 April 2009 - 11:44 AM
