Last fall I drained and blew out the water lines and Hot water tank with air pressure - or so I thought.
Had to prime the pump to get it going today. Could hear the hot water tank filling up but at some point water started gushing out of the cupboards. I pulled the cabinets apart as best I could but cannot see any of the hoses leaking. The water seems to be coming directly from under the hot water tank. Oh no!!
I can see the inlet to the tank and it doesn't appear to be leaking. Is it possible the tank itself is cracked from freezing? I don't see any way forward from this point but to remove the tank. How hard is it to do this? Is it just disconnect from the inside, remove the propane connection, from the outside remove the screws around the frame and pull out?
The model is a Hawk circa 2014.
Thanks for any help.
Edited by dcabernel, 14 June 2020 - 11:30 PM.
