1980's Four Wheel Camper Fleet Remodel Help and Discussion
four wheel camper four wheel campers fleet model truck camper truck camper remodel roof remodel portland oregon 1980s fleet model all terrain camper
22 replies to this topic
#21 HughDog
HughDog
  • 89 posts
Posted 21 August 2020 - 08:12 PM
Interesting timing, . . . I am at the exact stage and ran through one of Poky's threads ....  here is what was probably used on his and livin the dreams build .... I may do the same for my headliner.
https://www.upholste...e-hdl-1004.html
Edited by HughDog, 21 August 2020 - 08:12 PM.
2014 Ram 3500 MegaCab, 1983 FWC Fleet
#22 1980Keystone
1980Keystone
  • PipPip
  • 12 posts
  • LocationUtah
Posted 29 August 2020 - 08:06 PM
I'm a little late to this but I'll chime in with a couple of thoughts:
Patberry, Looks like you did a great job on the roof and headliner and the insulation. I'm sure just getting the improved R value out of the rigid foam will pay in spades, not to mention the leak-proofing you did. You're blessed with space to work with, so you might feel fortunate when you are having to repair more than anticipated. Some of us, like me, don't even have the space to take the roof off or put our camper on saw horses. I live in Utah and really haven't challenged my camper with Northwest rains. I grew up in Portland so I know that if someone even cracks a smile, it might lead to a leak somewhere. So you can take some confidence as well knowing that your camper is battle-tested. If more leaks appear and you can identify the source, you might try Marine Rx. The marine repair industry has products for many of the same purposes we have, and they've done it for years for a well-moneyed but demanding market.
Regarding others considering replacing the headliner: I thought a lot about replacing the insulation and headliner for my Keystone but ultimately did not for various reasons. I was already working on so much else with the camper that it was not a priority. I did my re-wiring and new LED lights by making a few, small slits in the headliner and running completely new wire on new DC circuit and fishing it through. I just left the dead wire up there. I used clear patching material over the small slits, which did not work perfectly, but works. After good cleaning, it doesn't look bad, really. At least not to me.
If I end up smelling or detecting mold, then I will remove the headliner and replace it with new insulation. I'm not sure how I would do it, but I might consider doing it in 2 pieces (or more) with the seam running along one of the ceiling struts. The seam would then be covered by the wood trim. That might be a way to do it without removing the top. But if you could remove the top, I think the way Patberry did it is best.
#23 Briandmiers
Briandmiers
    Newbie
  • Pip
  • 1 posts
Posted 23 October 2020 - 05:02 PM
New roof looks great! We just picked up our first FWC this week. It's a 1987 Fleet. I am curious if yours has new canvas and what the lifting panels look like? In your photos it looks like maybe the canvas was replaced. Did you do that after you purchased it?
Edited by Briandmiers, 23 October 2020 - 05:02 PM.
Also tagged with one or more of these keywords: four wheel camper, four wheel campers, fleet model, truck camper, truck camper remodel, roof remodel, portland oregon, 1980s fleet model, all terrain camper
