Just called PKYS and talked to Peter their tech person. The Victron controller only kicks in at 5 volts above the battery voltage. Zamps are rated at 18 volts. He also said the even at 19 volts [14+5] the MPPT would not optimize the amperage going into the battery, "Sweet Spot", it needs higher voltages. Even if you put panels in series to increase the voltage the MPPT with differing size panels the controller will not optimizer the power going into the batteries as it searches for best input or so-called Sweet Spot.
So the conundrum; with the Victron controller the optimal way to derive the benefit of the MPPT is to be using one panel of sufficient voltage to trigger the controller and give the optimal battery power input.
For me, whether I add another Zamp panel [90w] or not the MPPT is not going to give me a higher input of power to the batteries than my current Zamp PWM controller will provide. Too bad the partial shading of the panels to a degree is compensated for by a MPPT controller search/optimizing available power input to the batteries.
Solution: Add a higher out-put voltage single panel and then install the MPPT to optimize the power going into the batteries for a given size [Watts] panel. Currently no single large panel will fit on the roof of my Hawk.
I must be over thinking this and chasing my tail. PWM + another 90 w Zamp and keeping to 18 volt output is realistically my sole option. I simply do not have the roof space between, in-front of or behind the two roof vents for a single large [watts] panel.
Will buy the Victron battery monitor and perhaps go to LiPo4 batteries in the future.
If some of this is inaccurate, please chime in and clarify. I am still in my learning curve and the slope is steep!
Interesting that FWC does not offer dual roof mounted panels or a single high output panel; now that they are using the Victron Solar Smart MPPT controller. Wonder what the specs are on the current portable plug in panel? Assume it is also an Overland Sunpower panel
Thanks All,
Phil
Edited by Wallowa, 25 November 2020 - 05:29 PM.
