Edited by muttmaster, 22 December 2020 - 07:50 PM.
Couple things I noticed at 5 degrees F.
#31
Posted 22 December 2020 - 07:10 PM
#32
Posted 22 December 2020 - 07:13 PM
Dang...thanks to all for the input...lots of pearls of wisdom I would never have thought of...and put me in the "better safe than sorry" column.
Everyone have a great Christmas and New Year....
Phil
#33
Posted 22 December 2020 - 07:21 PM
Rando, I looked into splice in shut off valve in outside shower line but there is just no room in my Grandby. Short of taking the cabinet apart to even access the short hose, there isn’t enough space for a valve inline. If someone had a solution, I do it right away. It is the only weak point I worry about besides the main tank drain line. I can’t access that line easily either to put in a valve inside. I think 4WC should built in shutoff valves at these two lines in the future to prevent damage.
On my flatbed there is space for the valves in the small cupboard above the furnace. I added some push to connect valves to the pex run there. With those valves shut off, all the water system is contained within just one cabinet, that also contains the water heater. The water heater provides enough heat to keep this cabinet well above freezing. As for the drain line - I am sure mine has frozen particularly as I added a metal drain valve, but the tube is flexible braided tubing and is stretchy enough not to mind.
2016 Fleet Flatbed
2016 Toyota Tacoma
#34
Posted 22 December 2020 - 07:22 PM
Blowing out water lines...I have the screw on cap with the compressed air valve that attaches to my Hawk exterior water line fill fixture....
I assume you open drain on back wall of camper, open sink faucets, open exterior shower valve, open hot water tank drain into main water tank...before putting an air line on the screwed on cap..
Does this sound correct? Any tips?
Thanks...Phil
#35
Posted 22 December 2020 - 07:30 PM
Edited by muttmaster, 22 December 2020 - 07:55 PM.
#36
Posted 06 February 2021 - 03:07 PM
I just got back from mammoth Mtn here in CA where I camped in a blizzard for 3 days and then an additional 4 days of cold. Overnight I was seeing outside temps down to 5-10F and one night at -1F. I run a Goal zero Li battery pack which is exposed to the outer wall of my 2020 Grandby. I wrapped it in a sleeping bag and left the inside heater on low. The heater would kick on at ~37F and kick off at ~57F.propane. A single tank of propane lasted 6 days using the heater and occasional stove use. I took your advice and drained the water system. I used external jugs for water and had to manage keeping the ones in my truck back seat un frozen. All in all it worked out well. Ended up with 2-3ft of snow on the ground. I was prepared to rake the snow off of my roof however the high winds kept the snow from accumulating.
Steve
2012 F350 4x4
2020 Grandby
#38
Posted 06 February 2021 - 03:36 PM
2012 F350 4x4
2020 Grandby
#39
Posted 06 February 2021 - 04:00 PM
#40
Posted 06 February 2021 - 04:33 PM
Sounds like you did well in the Granby (i think granby) Steve.
Which thermostat do you have?
6 days from one propane tank means you went through a lot of fuel but if you slept well and got through it all fine sounds like things worked as they should.
also im curious as a comparison to what mine does in similar conditions...how often would you say the furnace cycled on and off in that 37 to 57 range you stayed in?
Nice setup and rig by the way. I like the FWC’s in black. I think that was a smart move on their part.
patrick
