Single LiFePo4 Battery or Two LiFePo4 Batteries in Hawk?
89 replies to this topic
#1 Wallowa
Wallowa
    Double Ought
  • 2,173 posts
  • LocationNE Oregon
Posted 11 January 2021 - 01:06 AM
I received a recommendation to use a single Battle Born 100AH battery in my '16 Hawk; rather than using two of the 100AH Battle Born batteries.  Replacing my two 75AH AGMs.
Other than cost and weight, is there an advantage to using a single battery?
I know that some times more is not better.  But can't wrap my head around going with 100AHs rather than 200AHs.   Assuming I have the space and funds!
Any experience you have had would help me in figuring this out...Thanks!
Phil
#2 Outnabout
Outnabout
  • 280 posts
Posted 11 January 2021 - 01:15 AM
Phil
My understanding is the 100ah Battleborn will still be more than your 2 AGMs of 150ah combined because you should only use 1/2 of the amp hours which would be 75 as opposed to being able to use all 100ah in the Battleborn. I’m sure you will get much more and knowledgeable advice from others.
#3 Ruck_and_Roll
Ruck_and_Roll
  • 144 posts
  • LocationGrand Junction, Colorado
Posted 11 January 2021 - 01:25 AM
I upgraded to 100 AH battle born.  Thought about going to 200 AH.  100 AH has been fine.  I do 100% boon docking.  My main power drain is the Truck Fridge 130.  With 260 watts of solar and DC charging from truck I don't think I have ever gone below 50% battery.  Before going to Lithium battery I also upgraded all the light fixtures to LED lighting.  Best thing to do would be to compute your power needs.  I think there are some posts regarding that in the past.  In my personal experience 100 AH has been plenty.
2021 Ford XL SuperCrew HD Payload Pkg
2008 FWC Hawk
Western Colorado, USA
Instagram: @lukeyfiasco
#4 Ted
Ted
    Magellan
  • Site Team
  • 2,781 posts
  • LocationEast of Sacramento
Posted 11 January 2021 - 02:45 AM
I would say it depends on your use. As R&R says above, one battery works for him with the main draw being the fridge. But if you are running the fridge, heater, charging phones, and using a plugged in laptop, that might be enough.
We are having a new rig built right now. We went with two lithium batteries and 400 watts of solar on the roof. I don't want to ever have to worry about enough battery charge.
"Not all who wander are lost. Except Ted, he's usually lost."  Dirty Dog
#5 Wallowa
Wallowa
    Double Ought
  • 2,173 posts
  • LocationNE Oregon
Posted 11 January 2021 - 03:15 AM
Thanks folks....appreciate you input.
Ted, I have 330w and while I don't use a laptop or anything other than the FWC installs, I also boondock a lot and constantly monitor what will eventually be our "limiter" that requires me to return to the 'chaos' ....propane, water and electrical power, gasoline for the truck...all else for us is fluff.........oh, forgot, also coffee and chocolate...but I carry a lot of both.... B)
Phil
#6 Jon R
Jon R
  • 929 posts
  • LocationWashington State
Posted 11 January 2021 - 04:39 AM
I'm planning to put two Battleborn 100Ah batteries in my new Grandby shortly after it's delivered.  I'm planning to install 400 watts of solar panels with a Victron MPPT 100/30, and an Orion 12/12-30 DC to DC charger.  It may be overkill, but I live in the Pacific Northwest where the weather is often cloudy.  I ordered the largest compressor fridge, and I expect my wife will run the heat some at night.  Other than that I'll have typical loads plus some phone and laptop charging.
  • 1
Jon R
2021 GMC 3500HD CC LB SRW Gas
#7 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,962 posts
  • LocationCalgary, Alberta
Posted 11 January 2021 - 05:13 AM
Phil, 100AH of Lithium is lots for your usage.  Its the equivalent of 200AH of AGM, and you only have 150AH now.  Save money for more chocolate or a new set of skis.
#8 LAWNMOWERMAN
LAWNMOWERMAN
  • 214 posts
Posted 11 January 2021 - 05:24 AM
Get 2-100 amp hour Battle Born batteries,you will not regret it.I have a Dometic compressor fridge and an ARB  50qt chest set at 5f.I also have a 1000 watt inverter for my 3qt Instant Pot and my coffee grinder.
  • 1
2017 Tacoma TRD 4x4 Offroad / 2014 ATC Bobcat / Tucson,Az
#9 Wallowa
Wallowa
    Double Ought
  • 2,173 posts
  • LocationNE Oregon
Posted 11 January 2021 - 05:28 AM
Vic...good wisdom...I believe you worked out that my Hawk as configured at full boogey will only draw 18a...  I understand that my 2x75AH AGMs at best when fresh and new could be used down 75AH and a 100AH Li could go at least to 80AH; and as I understand Li recharge quicker than my AGMs.....thanks for your advice.
Phil
#10 Dafinga
Dafinga
  • 36 posts
  • LocationNorthern Cali
Posted 11 January 2021 - 05:57 AM
Not to jump on this bandwagon but......Can I just drop Battleborns into my 2017 Hawk Flatbed to replace the AGMs?  I thought I would need a new solar controller and charging setup?
-Pete
