Propane tank valve leaking (replacements for horizontal OPD valve)?
12 replies to this topic
#11 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,966 posts
  • LocationCalgary, Alberta
Posted 07 October 2021 - 03:08 AM
I got mine (for previous camper) at a propane dealer here in Calgary.  I had options back then on where to buy.  Pricey, but new!
#12 RHarries
RHarries
  • 31 posts
  • LocationDurango, CO
Posted 07 October 2021 - 12:51 PM
Achiral,
it sounds like we have/had the same 20 pound Manchester tank with Sherwood valve.  Thanks for info re: 30 pound valve compatibility.  did you locate anyone to install the replacement valve?  i have asked all propane vendors in my region without success.  it seems like the cylinders are made to be disposable as nobody provides this service.  frustrating!
'15 Tundra Double cab with '09 Hawk side couch
#13 achiral
achiral
  • PipPip
  • 25 posts
Posted 08 October 2021 - 02:33 PM
Achiral,
I called a half-dozen different places to no avail (everyone just wants you to buy a new tank), then started focusing on small towns/small dealers up in the mountains or in the desert and just figured I'd stop by while on a trip.
I ended up going to a little 2-person propane shop in the middle of nowhere, where the employee swapped out the valve in 5 minutes. It's almost trivial to do the swap, but you need:
- standard OPD valve wrench & long lever (you can find them on-line)
- a couple of 2-3" wide ratchet straps
- and some type of strong post to strap the tank to. Something like a parking bollard or steel i-beam frame that are embedded in concrete would work
In any case, I didn't want to spend $100 on tools and parts to make the swap reasonably safe, and I figured people might get a bit upset if I was wrenching on a propane tank in a parking lot, so I had someone else do the replacement.
