Broken frame welds, front of 2000 Grandby
welds frame
10 replies to this topic
#1 Dr Paddle
Dr Paddle
  • PipPip
  • 12 posts
  • LocationSan Diego, California
Posted 05 October 2021 - 05:22 PM
Hi, folks -
My efforts to repair my 2000 Grandby continue. Latest discovery is that welds have broken on the three short frame tubes at the front of the camper. I expect this is from the camper banging into the lip of the truck bed (an issue I am addressing).
It's currently impractical to transport the camper to a welding shop. So, I'm planning to use stainless steel angle brackets (to prevent corrosion) and aluminum pop rivets to resecure the tubes. Any thoughts on this approach?
As most of us know, FWC only welded one of the four edges of the tubes. I understand they did that to enable more frame flex for offroading. However, it also makes those welds prone to breakage.
In the photo, I have displaced one of the tubes for emphasis. The other two identical tubes also have broken welds at one or both ends.
Thanks!
Kevin in San Diego
#2 Casa Escarlata Robles Too
    C'est la vie
  • Site Team
  • 8,756 posts
  • Locationmonterey bay area
Posted 05 October 2021 - 08:45 PM
Welcome to the WTW group.
The SS brackets might be the easiest method
to repair the detached frame member.
You could also use a triangle gusset.
Good luck with the problem.
#3 camelracer
camelracer
  • 945 posts
  • LocationGoleta, Ca
Posted 07 October 2021 - 01:30 AM
The combination of stainless and aluminum could cause galvanic corrosion problems.
2002 Fiat 2500 CTD 4x4, FWC Grandby 1951 Willys CJ3A
#4 joez3
joez3
  • 54 posts
Posted 07 October 2021 - 03:51 PM
I have never used these, maybe this would work for you: Aluminum Welding Rods - Pack of 8 Low Temperature Rods (harborfreight.com)
  • 1
#5 JediahPorter
JediahPorter
  • PipPip
  • 26 posts
Posted 11 October 2021 - 04:54 PM
I had the same breaks in my 1999 Hawk. I used angle brackets to repair a couple years ago. I haven't opened it up to inspect since... I guess that isn't too helpful.
Now I'm curious about the Harbor Freight low temp "welding" rods.
#6 Porkface
Porkface
  • 44 posts
  • LocationFisherville, KY
Posted 11 October 2021 - 06:17 PM
I've tried to use the low temp alu. welding rods before (not from Harbor Freight) and could never get a clean "weld". Due to the frame flexing here, I don't think a low temp "weld" (solder?) would last very long. I'd use the triangular gusset with rivets repair myself.
#7 Beach
Beach
  • 834 posts
Posted 13 October 2021 - 04:23 PM
Since you've discounted the welding option; Your bracket and rivet idea is probably the next best thing but consider bedding the brackets in a polyurethane adhesive(3m 5200) while installing(riveting), poly U will add a lot of strength plus it can flex without breaking or cracking. Flexible epoxy might be another choice. You might also consider adding flat T shaped gussets to the aluminum face of the framing, again bonding with adhesive and rivets.I don't think the thickness of the "face gussets" would affect the aluminum siding noticeably from laying down flat. The inside angles of the T brackets should be radiused and not square to prevent tearing during flexing motion. Be sure to rough up all surfaces you apply adhesive to and clean with a good grease remover/cleaner.
Edited by Beach, 13 October 2021 - 04:27 PM.
  • 1
#8 Wildcat
Wildcat
  • 86 posts
  • LocationCalifornia
Posted 19 October 2021 - 02:29 PM
The above idea of using some type of adhesive is worth considering. Keep in mind that modern auto industry manufacturing processes also uses ahesives, sometimes in lieu of welding. In your application for the tube repair given the small area of contact for the weld, a combo of gussets and ahesives might be the better than the original construction.
2001 FWC Eagle on 1998 Taco 4x4
#9 JaSAn
JaSAn
    Grumpy Old Man
  • 1,013 posts
  • LocationMinnesota
Posted 19 October 2021 - 10:56 PM
^^ what Wildcat said.
I would talk with an application engineer from 3M, Loctite, or other major adhesive manufacturer.
They glued together a bridge across the St. Croix River a couple of years ago, so they should have an adhesive that is strong enough for your application.
Renovating Skoldpaddan
2012 Ram 2500 4X4
1951 Dodge Power Wagon
#10 Dr Paddle
Dr Paddle
  • PipPip
  • 12 posts
Posted 31 October 2021 - 07:13 PM
The suggestions from Beach, Wildcat, and JaSAn to use adhesives and brackets arrived just a bit late for my repair. Great ideas, though. I'll keep an eye on my repair and, if the brackets and rivets I used fail, I'll go with glue. Thanks!
BTW, I just posted in a new thread the video my daughter made of her trip in the camper through wild Utah. She had a blast!
Also tagged with one or more of these keywords: welds, frame
