Counter point...the furnace in my 2016 Hawk, unmodified, has worked perfectly at -15 F and at 9,800 ABSL....of course we are only a sample of 1.
Scame here, 2018 hawk up to 10,300 ft but not so cold and I replaced the analog thermostat with a digital. Key is lithium batteries which will continue to operate properly at low temps. N=2
I think that the design of the low amperage model heater, which is already operating at a minimal airflow to keep amp usage low, does not allow for even a tiny restriction of the airflow. I think some of the campers are assembled with just enough of an offset from the heater to the register that there is a bit more air restriction in the duct and …no heat at lowered air density, or low voltage in batteries. Either way, not enough flow and sail switch cuts it off.
Edited by Mthomas, 13 October 2022 - 09:32 PM.
