Edited by Jon R, 26 August 2023 - 10:45 PM.
FWC Victron DC to DC charger upgrade help / 2017 Hawk
#21
Posted 26 August 2023 - 10:40 PM
Jon R
2021 GMC 3500HD CC LB SRW Gas
#22
Posted 26 August 2023 - 11:19 PM
I also plan to installed fused 6 AWG to replace the 10 AWG , however I am unsure if this upgrade is necessary if I don't rely on or need the truck alternator charging capability (?)
Jon R seems to have capably answered all of your questions so far. My turn, I have a question about the above sentence. The only reason you replaced the surepower separator with a DCDC converter IS to charge off of your alternator. So, yes, I would replace it with 6awg... but I am confused by your statement above.
#23
Posted 27 August 2023 - 02:08 AM
Hi Vic,
Sorry for the confusion, I understand now that statement was incomplete.
I want to try and run the setup with the OEM 10 AWG initially to see if/how I will benefit from increased charging capability with the 6 AWG upgrade. Upgrading the wiring will require removal of the camper from my vehicle, which is complicated for a variety of reasons.
I was/am concerned that the 10 AWG may generate excessive heat and damage the Victron DC-DC charging system.
The reason for installing the replacing the Surepower battery separator with the DC/DC charger was to allow proper charging of the the new LiPO4 battery, albeit slowly until the wiring upgrade is made.
FWIW, I dont use much electric power, and historically the 100 AH AGM battery and 90 watt solar panel were sufficient for my needs, until Starlink came along and started depleting my power supply rapidly. I felt the LiPO4 battery would be more robust, and allow deeper discharges. Now I have the Victron MPPT, Orion DC-DC to supplement the 712 BVM.
Presently I have all installed as planned, yet now I am mired in trying to understand if my alternator is a "smart" alternator or not (2015 Tundra). Voltage is measure at 13.9 V at the camper battery at start up and 13.4 after idling for ~15 minutes. I want to make sure i set up the Orion thresholds properly.
'15 Tundra Double cab with '09 Hawk side couch
#24
Posted 27 August 2023 - 04:10 AM
I also got mired in the "smart" alternator issue for our Tacoma. Our Renogy dual charge controller has a sensor wire that I have hooked up to the trailer positive line to sense engine on. But to be honest we don't use that. We seem to get 25-ish amps from the 30A charge controller into the battery, (and close to 30A with the sensor wire). I never did fully determine if our 2018 Taco has a smart alternator.
Our power needs sound similar to yours before you added Starlink, and the 90W solar seems to keep our battery up to 100% SOC on sunny days.
Tacoma/Fleet 2018.
#25
Posted 27 August 2023 - 05:01 AM
Toyota? My 2002 Tundra had a smart alternator, so you likely do as well. The 10AWG won't damage your DCDC. And you can used the voltage settings for "engine running detect" on the Victron to set yours up, anything over 12.9 v is likely more than the resting voltage of your starting (AGM) battery, so setting it to 13.3 will likely kick off the charging processes. Only question is how much voltage drop you will get at 30A over 10AWG. Good thing to test and see.
#26
Posted 30 August 2023 - 12:37 PM
I am finding (as many others have), that the 10 AWG wire is causing cycling of the DC charger. I plan to upgrade the wiring this weekend, and am curious about mounting the Anderson power pole connections to the truck bed and camper. Does anyone have photos of a good way to affix these terminals?
#27
Posted 30 August 2023 - 02:53 PM
I ran 2 lengths of 2awg from my engine compartment to the bed of the truck. On one install I drilled holes in the truck bed, installed rubber grommets and the Anderson Powerpole connectors just lay in the truck bed.
Current install uses insulated through-hull power studs from Summit Racing. The powerpole connectors have a hole in the middle for a screw. You can buy mounts for them or simply screw the it to the bed.
#28
Posted 30 August 2023 - 03:40 PM
Trailer Vision has a mounting bracket that can be secured to the cargo bed wall of the truck.
https://www.amazon.c...F9kZXRhaWw&th=1
Andrew in Austin, TX
#29
Posted 30 August 2023 - 04:12 PM
in addition to what Vic states, one time after a trip (we drive rough roads) I discovered the two halves of my powerpole connectors had vibrated apart. I now wrap a plastic cable tie around the two joined halves and no more issue with this.
2003 Ford Ranger FX4 Level II 2013 ATC Bobcat SE "And in the end, it's not the years in your life that count. It's the life in your years."- Abraham Lincoln http://ski3pin.blogspot.com/
#30
Posted 30 August 2023 - 07:57 PM
I decided I like it that way and that is now my permanent method. The connection is completely out of sight, and the wires coming over the front wall are not noticeable unless you look for them.
Jon R
