Using tow/haul mode with lighter campers
14 replies to this topic
#11 pvstoy
pvstoy
  • 2,775 posts
  • LocationCarson City, NV
Posted 03 May 2023 - 12:39 AM
We have a 2012 dodge 2500 crewcab gasser with flatbed hawk. Seems the benefit is when on cruise control at speed going up rolling hills the engine drops rpm and speed that a much lower gear is selected with way too much throttle to try to bring the set speed back.
At the bottom of a hill that I think the cruise can't handle I press the tow haul button, kicks down a gear, raises the rpm a bit a runs the hill just fine.
To note I can press to engage and then press to release. The setting will stay engaged until the top or load is not needed any more.
Have not noticed any other advance. For downhill doesn't seem to kick in to help slow down.
Patrick
2015 FWC Hawk Flatbed
#12 JaSAn
JaSAn
    Grumpy Old Man
  • 1,106 posts
  • LocationMinnesota
Posted 03 May 2023 - 02:09 AM
I use tow/haul when I feel the transmission shifting a lot, trying to find the right gear.  Or when, from experience, I know the transmission is going to start trying to find the right gear.
2012 Ram 2500 + Grandby: about 8000 lbs loaded.
  • 1
Renovating Skoldpaddan
2012 Ram 2500 4X4
1951 Dodge Power Wagon
#13 Outnabout
Outnabout
  • 280 posts
Posted 03 May 2023 - 02:24 AM
I use tow/haul on steeper hills so the transmission doesn’t keep looking. On steep downhills I also use it in conjunction with the exhaust brake. I have a Ram with the Grandby.
#14 Sleddog
Sleddog
  • 182 posts
  • LocationIdaho
Posted 03 May 2023 - 12:01 PM
I use it regularly with my 2010 Tundra. Most of my driving is up and down mountain passes, I like the shift pattern going up hill and the braking/downshifting it provides going down hill. I will turn it off for long, flat stretches to help with gas mileage.
#15 Taku
Taku
    Buffalo Rockface
  • 757 posts
Posted 03 May 2023 - 07:14 PM
2021 Tundra with ATC Cougar camper. i use the tow/haul on long grades over passes, but that is really about it. it certainly does help with the power for pulling a long grade.
2005 Tundra  2013 Ocelot    "Ridiculously comfortable"
2021 Tundra 2022 Cougar Shell Built Out  "Even more ridiculously comfortable"
