Fleet Refurb Furnace Question
fleet furnace rebuild help
  • Please log in to reply
5 replies to this topic
#1 Serat
Serat
  • PipPip
  • 15 posts
  • LocationColorado
Posted 14 May 2023 - 12:47 AM
Hi Everyone,
I just got my hands on a Fleet of unknown vintage (somewhere between 2006 and 2009, maybe) and I am refitting it.  I figured I'd just pull the old furnace and pop a new Dometic model into the hole.  The old furnace is a Dometic/Atwood 8516-IV.  The guy I bought it from said it worked but I couldn't get it to light.  Fan was okay, though.
The new furnaces are 3 inches longer than the old one.  And, yes, I have learned an important lesson about removing something prior to researching a replacement!
My options seem to be:
1.  Fix the old one (if possible) and put it back in.  I saved the circuit board and thermostat but who knows if they work.
2.  Cut 3 inches out of the wooden platform directly behind the furnace and get a new Dometic.
3.  Try something entirely different like Propex or Truma (gasp$$).
I really want to go with option 2.  Is there a problem if I cut down that little bump out where I drew the line in the photo?  I would replace the wood on the end and patch the hole in the floor, of course.
Any advice for a newbie?
Roylnn
#2 veryactivelife
veryactivelife
  • 188 posts
  • LocationMaryland
Posted 15 May 2023 - 12:13 AM
Isn’t that round hole the access for setting the turnbuckle? I don’t have turnbuckles as my camper is bolted down to a flatbed, so I’m not the last word on advice. But, I believe that the turnbuckle will be angled towards the rear of the camper so make sure shortening that boxed area doesn’t interfere with properly installing the turnbuckle. Basically that box is to allow the camper to clear the inner wheel well.
Dean
Dean and Mary
2015 RAM 2500 Cummins with 2015 Four Wheel Campers Hawk flatbed
VeryActiveLife on Facebook, instagram & YouTube
#3 TacomaAustin
TacomaAustin
  • 171 posts
  • LocationAustin, Texas
Posted 15 May 2023 - 10:36 AM
Since you have the furnace out of the camper, my preference would be to have the existing Atwood 8516 unit repaired.
  • 1
Andrew in Austin, TX
#4 ski3pin
ski3pin
    Belay On
  • Site Team
  • 15,338 posts
  • LocationSierra Nevada Range
Posted 15 May 2023 - 06:56 PM
Exactly. Plus you will learn how the furnace works and how to repair it. There's not much difference between new and old in how they operate. Parts are available and there are repair videos on YouTube.
#5 kmcintyre
kmcintyre
  • 1,384 posts
  • LocationBoise, ID
Posted 20 May 2023 - 10:43 AM
If it's the original control board, I suspect that's the issue.  Did it start up and just not light?  When I rebuilt my old Eagle, I replaced everything (sail switch, jets, etc.; all cheap) and then had to do the circuit board.  I cleaned the flu, put a bit more insulation around the unit (top/sides), etc.   I went with a Dinosaur brand and it worked great for many years until I sold the Eagle.  Since it's out, you have a lot of options of what you could do (wiring, outlets, etc., etc.).
Boise, ID
2022 Chevy 3500 HD
2023 FWC Flatbed Hawk
#6 Serat
Serat
  • PipPip
  • 15 posts
  • LocationColorado
Posted 21 May 2023 - 06:51 PM
I thought I'd update this for those of you kind enough to reply. I did not have the courage to cut out that corner of wood, or the patience to become an HVAC technician so I have decided to get a new dometic and relocate it.
I may start a rebuild thread. Although, after reading several very complete threads on here, I doubt I'll have much to add!
  • 1
Also tagged with one or more of these keywords: fleet, furnace, rebuild, help
