I just found out my Gaia annual subscription is going from $39.95 to $59.99. That’s a pretty big jump! I don’t use it that much (unfortunately) so I am canceling it. I usually use Google maps and I will mark out a route using back roads whenever possible on Benchmark Maps. But I would like to have something for off road and out of cell service. I’m going to see just how much if anything I can get off of just the Gaia app. I may try ONX (?) or something different just out of principle but from what I’m reading here I don’t know.
Gaia GPS Navigation
#41
Posted 08 January 2024 - 02:24 PM
2007 Tundra 5.7L Dbl cab
2020 Hawk Shell
#42
Posted 09 January 2024 - 01:26 AM
The biggest issue with Backcountry Navigator is their use of a propitiatory .bcn file system. .
For future reference: It's possible to get the waypoints out of Backcountry Nav. The .bcn files are "sqlite" files, an open-source file format. Use the free software at https://sqlitestudio.pl/ to edit the file, which can display a spreadsheet of all the waypoints. Then you can paste them into your own spreadsheet, and add a cell in each row to create the proper GPX format from other columns. I used this:
="<wpt lat=""" & B57 & """ lon=""" & C57 & """><name>" & E57 & "</name><desc>" & F57 & text(G57,"YYYY-MM-DD") & "</desc></wpt>"
(oops, I forgot the time from column G... might edit this later...) used to build a GPX file something like this:
<?xml version="1.0"?> <gpx xmlns="http://www.topografix.com/GPX/1/1" xmlns:gpxx="http://www.garmin.com/xmlschemas/GpxExtensions/v3" creator="CALTOPO" version="1.1"> <wpt lat="36.12345" lon="-117.67890"><name>Some bogus waypoint</name><desc>2023-01-08 </desc></wpt> <wpt lat="36.234567" lon="-117.0987654321"><name>Another waypoint</name><desc>2023-01-08</desc></wpt> </gpx>
If this looks complicated, private-message me if you want one converted. It's just a few minutes.
Tacoma/Fleet 2018.
#43
Posted 09 January 2024 - 03:33 AM
rubberlegs is a computer genius and has set my waypoints free! Thank you sir.
2003 Ford Ranger FX4 Level II 2013 ATC Bobcat SE "And in the end, it's not the years in your life that count. It's the life in your years."- Abraham Lincoln http://ski3pin.blogspot.com/
#44
Posted 09 January 2024 - 10:44 PM
ahhh yes, sqlite files. i should have known that.
but first i have to figure out how my cursor got locked..... wth...
Oregon
