I don’t know the exact dimensions of a 2010 Hawk. However, I did ask this same question about my 2021 GMC HD long bed and a 2021 Grandby. It was too short by an inch plus even if I was to shave the front camper bumpers to have only 1/2” clearance to the front bed rail.
While they called it a 98 inch bed, that length is only available below the top of the front bed rail. The front rail comes back about 2” from the front bed wall at the floor. The distance from the top rail of the front of the bed and the inside of the tailgate is about 96.25 inches.
So for your 2024 standard bed question be aware of the same issue with the stated bed length in the specs being the floor length, not the top rail to tailgate length. Also, there is hardware on the back of the camper that sticks out about 1.5” beyond the camper back wall. My guess is it won’t quite fit, but I don’t know that.
Finally, while I thought I would want the tailgate on if my camper would fit, once I used the camper I quickly realized that, because of the short low entry door, it works best for me to be stepping up from below as I enter and stepping down as I exit. That way I don’t need to bend over much getting in and out. I’m 6’0”. I use a plastic two-step ladder for access.
The camera issue can be addressed with a camera on the camper. I bought a GM camera for $100, a FAKRA cable, and made an enclosure out of a pvc 45 degree ell. It’s mounted in the same position as the tailgate camera so the views don’t change.
Edited by Jon R, 07 March 2024 - 03:23 AM.
