Posted 31 January 2011 - 04:41 PM
I have a similar story, I went out camping this last weekend and I kept getting the "ignition lockout fault" (three blinks of the LED). fan spins, burner ignites for maybe 2-3 seconds then stops, three times then locks out. well after trying that maybe a dozen times and reseting with the reset switch it would fire and run fine through the night. next morning, same thing, kept giving me the lock out code. so I got home and pull the burner apart to check for build up, it was really clean and nothing obvious was observed. so I tried again and I got it going after abotu three resets. Any thoughts? I turned the pressure up slightly in the regulator (3/4 of a turn) after reading something somewhere else, did not seem to make a difference. battery is fully charged, fan is running, sail switch hits, burner ignites for 3 seconds then off. only thing left I can think of is the board is bad and somehow not "proofing" there is flame some of the time.
2008 FWC Eagle, 3 way fridge, heat, custom cabinet top/side hatch, solar charge system. all that sitting on an 07' Nissan Frontier, lifted, locked and ready.
