Real numbers for Engle and solar
#11
Posted 09 January 2011 - 10:55 PM
With 2 large dogs (and hopefuly another human if things work out), the MT45 was not gonna work.
DSRTRAT: Do you think that would work for the front open model??
2006 GMC Sierra 2500HD 4x4 (LBZ) Duramax Diesel& 2002 Hawk, 2 dogs and a lust for adventure ;-)
#12
Posted 10 January 2011 - 04:52 AM
It should.DSRTRAT: Do you think that would work for the front open model??
I used it in my 3 way before I switched to the Engel and it worked fine. The sensor wire is very small and air leakage is minimal.
Dsrtrat
#14
Posted 10 January 2011 - 06:48 PM
I have the front open SR-70.
randygirl, how do you like the Engel so far? Is it very noisy? I'm a light sleeper so I can't have any noisy appliances running all night.
2010 Ford F250 4X4; 6.4 Powerstroke Diesel; Warn 16.5 winch; Airlift Springs; Transfer Flow 47 gal. fuel tank, BDS 4" lift kit, BDS dual steering stabilizer with upgraded Fox 2.0 shocks, Toyo 35X12.50X18 Open Country M/T tires, Pro Comp wheels; 2008 FWC Hawk Camper; 2000 Toyota Tundra.
#15
Posted 11 January 2011 - 09:50 PM
Love the Engel so far. It is a bit noisier than I was expecting, but it does not bother me. It ran only about 2 hours total overnite last nite. I went to my firend's property and spent the nite. Battery held up fine. It was overcas all day and it still got plenty of charge from the solar. 17 volts to be exact. I was surprised cause there was NO sun!!
#16
Posted 12 January 2011 - 01:19 AM
randygirl,
You and I have the exact same solar set-up and I too have been very pleased with the performance of the system. I think the remote mount meter is one of the best parts of the system with all of the information it displays. It really displays a huge amount of information about the solar systems performance.
As for the inside temperature of my refrigerator, I use one of these cheap units:
http://www.amazon.co...r/dp/B000GGFYHW
So far it has worked flawlessly.
#17
Posted 12 January 2011 - 01:22 AM
When you installed, did you leave two inches air space around the sides and in back? Spoke with Engel and that's what they recommend, although I thought I read somewhere that someone insulated the sides, which might make it more quiet.
#18
Posted 13 January 2011 - 04:52 PM
Randygirl,
Rob,
I have the 2 inches everywhere but in the back. I did not insulate the opening... I did cut a vent out in the space between the couter (where the sink is) and the top of the fridge compartment. Seems to work fine...
